查看: 17282|回复: 8
米家开关无法识别到
发表于 2017-12-16 20:27:27 | 显示全部楼层 |阅读模式
我用HASS.IO + homebridge 把小米网关挂到了HomeKit上,可以正常控制网关灯,今天新增了一个小米零火单键开关,在小米的米家APP下可以正常使用。但在HomeKit上无法识别到这个新增开关。
挂在小米网关下的设备在HomeKit是不是可以真接使用呢?还是configuration.yaml 这里面设置什么吗?
发表于 2017-12-16 20:43:29 | 显示全部楼层
我是用ha的自动化来控制的。
hb好像不支持无线开关吧?
27hh
教程狂人论坛风云人物
发表于 2017-12-16 21:04:01 | 显示全部楼层
设备都是需要手动接入的,玩HA就得做好不能即插即用的准备……
wqqs 手机认证
活跃会员
发表于 2017-12-16 21:14:54 | 显示全部楼层
小米零火开关是支持的
The xiaomi_aqara component allows you to integrate Xiaomi Aqara-compatible devices into Home Assistant.
Supported Devices
  • Temperature and Humidity Sensor (1st and 2nd generation)
  • Motion Sensor (1st and 2nd generation)
  • Door and Window Sensor (1st and 2nd generation)
  • Button (1st and 2nd generation)
  • Plug aka Socket (Zigbee version, reports power consumed, power load, state and if device in use)
  • Wall Plug (reports power consumed, power load and state)
  • Aqara Wall Switch (Single)
  • Aqara Wall Switch (Double)
  • Aqara Wall Switch LN (Single)
  • Aqara Wall Switch LN (Double)
  • Aqara Wireless Switch (Single)
  • Aqara Wireless Switch (Double)
  • Cube
  • Gas Leak Detector (reports alarm and density)
  • Smoke Detector (reports alarm and density)
  • Gateway (Light, Illumination Sensor, Ringtone play)
  • Intelligent Curtain
  • Water Leak Sensor
  • Battery
建议检查一下:
1.HA只能管理加到二代网关下面的开关,不支持加到空调伴侣下面的开关
2.homebridge_hidden: false
参与人数 1金钱 +10 收起 理由
+ 10 狮子666
发表于 2017-12-16 21:33:10 | 显示全部楼层
wqqs 发表于 2017-12-16 21:14
小米零火开关是支持的
The xiaomi_aqara component allows you to integrate Xiaomi Aqara-compatible devi ...
赞,刚想起还需要再hb的插件配置文件里面加入 switch 支持。
"platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://127.0.0.1:8123",
    "password": "yourapipassword",
    "supported_types": ["automation", "binary_sensor", "climate", "cover", "device_tracker", "fan", "group", "input_boolean", "light", "lock", "media_player", "remote", "scene", "script", "sensor", "switch", "vacuum"],
    "default_visibility": "hidden",
    "logging": true,
    "verify_ssl": true
参与人数 1金钱 +10 收起 理由
+ 10 谢谢分享!
 楼主| 发表于 2017-12-17 13:57:34 | 显示全部楼层
neroxps 发表于 2017-12-16 21:33
赞,刚想起还需要再hb的插件配置文件里面加入 switch 支持。[code]"platforms": ...
要如何在配置文件中加入对 switch 支持呢?小白一枚请大神详解
发表于 2017-12-17 14:26:28 | 显示全部楼层
supported_types 这个选项里面加入 switch。我之前回复给你的就是整个插件配置的例子
 楼主| 发表于 2017-12-17 16:52:08 | 显示全部楼层
neroxps 发表于 2017-12-17 14:26
[code]    "supported_types": ["automation", "binary_sensor", "climate", "c ...
supported_types 这个选项里面本来已经有了 switch ,现在还能怎么整呢?在这里卡壳好几天了,郁闷啊
GMT+8, 2025-11-6 03:57 , Processed in 0.053163 second(s), 9 queries , MemCached On.
