查看: 2358|回复: 1
[求助] node-red 安装HA节点失败
发表于 2023-5-17 12:01:01 | 显示全部楼层 |阅读模式
群辉docker中启动成功,安装节点node-red-contrib-home-assistant-websocket 0.49.1失败,请问各位大神是什么原因。
2023-05-17T03:46:39.837Z 安装 : node-red-contrib-home-assistant-websocket 0.49.1
2023-05-17T03:51:55.159Z [err] npm
2023-05-17T03:51:55.162Z [err]
2023-05-17T03:51:55.163Z [err] WARN
2023-05-17T03:51:55.163Z [err] deprecated
2023-05-17T03:51:55.163Z [err]  [email protected]: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
2023-05-17T03:51:55.360Z [err] npm
2023-05-17T03:51:55.360Z [err] WARN
2023-05-17T03:51:55.361Z [err] deprecated
2023-05-17T03:51:55.361Z [err]  [email protected]: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
2023-05-17T03:51:56.182Z [err] npm
2023-05-17T03:51:56.182Z [err]  WARN deprecated [email protected]: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
2023-05-17T03:51:58.036Z [err] npm
2023-05-17T03:51:58.037Z [err] WARN deprecated [email protected]: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
2023-05-17T03:52:21.239Z [err] npm
2023-05-17T03:52:21.239Z [err]  WARN deprecated [email protected]: Backported compatibility to node > 6
2023-05-17T03:52:37.440Z [err] npm
2023-05-17T03:52:37.440Z [err] WARN deprecated [email protected]: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
2023-05-17T03:52:38.846Z [err] npm WARN
2023-05-17T03:52:38.847Z [err]  deprecated [email protected]: versions < v5.0.0 do not handle NUL in passwords properly
2023-05-17T03:52:41.062Z [err] npm
2023-05-17T03:52:41.063Z [err]
2023-05-17T03:52:41.063Z [err] WARN
2023-05-17T03:52:41.063Z [err] deprecated
2023-05-17T03:52:41.063Z [err]  [email protected]: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
2023-05-17T03:52:42.467Z [err] npm
2023-05-17T03:52:42.467Z [err] WARN deprecated [email protected]: request has been deprecated, see https://github.com/request/request/issues/3142
2023-05-17T03:52:42.892Z [err] npm
2023-05-17T03:52:42.892Z [err] WARN
2023-05-17T03:52:42.893Z [err] deprecated
2023-05-17T03:52:42.893Z [err]  [email protected]: This version of tar is no longer supported, and will not receive security updates. Please upgrade asap.
2023-05-17T03:52:48.632Z [err] npm WARN
2023-05-17T03:52:48.633Z [err] deprecated [email protected]: this library is no longer supported
2023-05-17T03:52:49.515Z [err] npm
2023-05-17T03:52:49.516Z [err]
2023-05-17T03:52:49.516Z [err] WARN
2023-05-17T03:52:49.516Z [err] deprecated
2023-05-17T03:52:49.516Z [err]  [email protected]: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
2023-05-17T03:53:15.607Z [err] npm
2023-05-17T03:53:15.607Z [err] WARN
2023-05-17T03:53:15.608Z [err]
2023-05-17T03:53:15.608Z [err] deprecated
2023-05-17T03:53:15.608Z [err]  [email protected]: you can use npm install i18next from version 2.0.0
2023-05-17T03:53:37.268Z [err] npm WARN
2023-05-17T03:53:37.268Z [err] deprecated [email protected]: Mailparser versions older than v2.3.0 are deprecated
2023-05-17T03:53:37.461Z [err] npm WARN
2023-05-17T03:53:37.461Z [err] deprecated [email protected]: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
2023-05-17T03:53:42.022Z [err] npm WARN
2023-05-17T03:53:42.022Z [err] deprecated [email protected]: This project is unmaintained
2023-05-17T03:53:45.142Z [err] npm
2023-05-17T03:53:45.142Z [err] WARN
2023-05-17T03:53:45.143Z [err] deprecated
2023-05-17T03:53:45.143Z [err]  [email protected]: This project is unmaintained
2023-05-17T03:53:47.013Z [err] npm WARN
2023-05-17T03:53:47.013Z [err] deprecated [email protected]: This project is unmaintained
发表于 2023-5-17 12:55:15 | 显示全部楼层
这些警告信息表明安装过程中出现了一些问题,但并没有明确指出安装失败的原因。可能的原因包括:
依赖项版本不兼容:安装的版本可能与其他依赖项不兼容,导致安装失败。您可以尝试升级或降级依赖项,或者查找更兼容的版本。
网络连接问题:安装过程中可能出现了网络连接问题,导致安装失败。您可以尝试重新安装,或者检查您的网络连接是否正常。
系统配置问题:安装过程中可能出现了系统配置问题,导致安装失败。您可以尝试查找并解决这些
GMT+8, 2025-12-17 14:06 , Processed in 0.270762 second(s), 6 queries , MemCached On.
