查看: 4618|回复: 4
[硬件DIY] 请问各位大神用esphome怎么写一个控制4路继电器的代码阿
发表于 2023-5-9 22:33:29 | 显示全部楼层 |阅读模式
请问各位大神用esphome怎么写一个控制4路继电器的代码阿,我这样写HA里面只有一个开关
esphome:
  friendly_name: jdq
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xm3+fXwQbc+HCjMvc0Kauk8ciXliOycM0THVV7LzbQ4="
ota:
  password: "821ca9d191fb11c9802a0db44bb08481"
wifi:
  ssid: "111"
  password: "2323232323"
  ap:
    ssid: "Csjdq Fallback Hotspot"
    password: "7W9WJX5mCxKK"
captive_portal:
switch:
  - platform: gpio
    pin: GPIO5
  - platform: gpio
    pin: GPIO4
  - platform: gpio
    pin: GPIO14
  - platform: gpio
    pin: GPIO12
发表于 2023-5-10 02:34:15 | 显示全部楼层
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "WiFi名称"
  password: "WiFi密码"
# 4路继电器驱动器配置,4路继电器分别连接D1,D2,D3,D4引脚
# 注意,这里的引脚号是ESP8266 GPIO的编号,并非实际的引脚号
# 请参考ESP8266引脚图使用正确的引脚号
output:
  - platform: gpio
    pin: D1
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D3
  - platform: gpio
    pin: D4
# 通过MQTT控制继电器
mqtt:
  broker: mqtt_broker_ip_address
  username: mqtt_username
  password: mqtt_password
# 控制面板,用于在Home Assistant上控制继电器,以及实现状态查询
switch:
  - platform: mqtt
    state_topic: "my_relay/relay1_status"
    command_topic: "my_relay/relay1"
    qos: 0
  - platform: mqtt
    state_topic: "my_relay/relay2_status"
    command_topic: "my_relay/relay2"
    qos: 0
  - platform: mqtt
    state_topic: "my_relay/relay3_status"
    command_topic: "my_relay/relay3"
    qos: 0
  - platform: mqtt
    state_topic: "my_relay/relay4_status"
    command_topic: "my_relay/relay4"
    qos: 0
# 定义实体状态,传送给Home Assistant
# 这里实现了状态查询功能
interval:
  - interval: 1s
    then:
      - mqtt.publish:
          payload: !lambda |-
            if (id(relay_1).state) {
              return "ON";
            } else {
              return "OFF";
      - mqtt.publish:
          payload: !lambda |-
            if (id(relay_2).state) {
              return "ON";
            } else {
              return "OFF";
      - mqtt.publish:
          payload: !lambda |-
            if (id(relay_3).state) {
              return "ON";
            } else {
              return "OFF";
      - mqtt.publish:
          payload: !lambda |-
            if (id(relay_4).state) {
              return "ON";
            } else {
              return "OFF";
上述代码中,我们首先配置了WiFi模块的连接和4个继电器驱动器的GPIO引脚等基本设置。接着,我们通过MQTT实现了在Home Assistant中通过MQTT控制继电器的功能。同时,订阅了相关的状态主题信息,用于状态查询。
在使用此代码之前,请根据你使用的芯片型号和引脚连接,进行必要的修改。你还需要根据你的MQTT服务器信息,进行相应的修改。
 楼主| 发表于 2023-5-10 10:07:39 | 显示全部楼层
Midnight 发表于 2023-5-10 02:34
esphome:
  platform: ESP8266
感谢大佬,很详细
发表于 2023-5-10 10:16:23 | 显示全部楼层
https://bbs.hassbian.com/forum.p ... mp;extra=#pid526900
这里有2种4路继电器的参考配置
yc21
发表于 2025-3-5 23:30:51 | 显示全部楼层
受教了,谢谢
GMT+8, 2026-2-2 19:38 , Processed in 0.059212 second(s), 10 queries , MemCached On.
