查看: 7744|回复: 6
[已解决] 群晖 homebridge启动后加载插件出错,请问如何...
发表于 2017-12-15 15:04:02 | 显示全部楼层 |阅读模式
插件中只有homebridge-synology能加载
E: Unable to locate package libavahi-compat-libdnssd-dev
npm ERR! code EINVALIDTAGNAME
npm ERR! Invalid tag name "homebridge-homeassistant": Tags may not have any characters that encodeURIComponent encodes.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2017-12-15T03_21_55_152Z-debug.log
npm ERR! Invalid tag name "homebridge-broadlink-rm": Tags may not have any characters that encodeURIComponent encodes.
npm ERR!     /root/.npm/_logs/2017-12-15T03_21_56_909Z-debug.log
[2017-12-15 03:22:11] Loaded plugin: homebridge-synology
[2017-12-15 03:22:11] Registering accessory 'homebridge-synology.Synology'
[2017-12-15 03:22:11] ---
[2017-12-15 03:22:11] Loaded config.json with 1 accessories and 0 platforms.
[2017-12-15 03:22:11] Loading undefined platforms...
[2017-12-15 03:22:11] Loading 1 accessories...
[2017-12-15 03:22:11] [Synology] Initializing Synology accessory...
[2017-12-15 03:22:11] [Synology] s
install.sh配置如下:
#!/bin/bash
apt-get install libavahi-compat-libdnssd-dev
npm install -g homebridge-homeassistant
npm install -g homebridge-broadlink-rm
npm install -g homebridge-synology
发表于 2018-2-6 08:35:00 | 显示全部楼层
请问楼主解决了么?我也发现这个问题,一直无法启动
 楼主| 发表于 2018-2-6 11:23:51 | 显示全部楼层
群晖docker吗?
发表于 2018-2-8 10:57:09 | 显示全部楼层
同样的问题
 楼主| 发表于 2018-2-8 12:16:30 | 显示全部楼层
这个错误暂时没办法,运行完成后在终端机里面安装需要的组件就可以了,后面启动就会自行安装
发表于 2018-2-24 00:03:41 | 显示全部楼层
刚遇到了类似问题,提示 Unable to locate package libavahi-compat-libdnssd-dev 之类的信息,后来发现是在win电脑上新建install.sh等文件的格式默认dos格式,用ue32之类的编辑器重新保存为unix格式的就ok了。
发表于 2018-9-1 00:09:59 | 显示全部楼层
pwcpp 发表于 2018-2-24 00:03
刚遇到了类似问题,提示 Unable to locate package libavahi-compat-libdnssd-dev 之类的信息,后来发现是 ...
感谢分享,刚好碰到这个问题,用您这个方法有效解决了!
GMT+8, 2025-12-24 21:34 , Processed in 1.588880 second(s), 11 queries , MemCached On.
