查看: 8088|回复: 6
新增的小米单键开关 无法被HomeKit识别到
发表于 2017-12-15 14:30:12 | 显示全部楼层 |阅读模式
小米的网关可以正常被 HomeKit识别到 但新增加的 单键开关无法被识别到 在米家APP下可以正常使用,这是那里设置什么吗,请大神们指点
发表于 2017-12-15 16:12:51 | 显示全部楼层
無配置找不都問題所在,怎樣幫你~~
发表于 2017-12-15 16:30:07 | 显示全部楼层
嗯 问题描述要详细点
 楼主| 发表于 2017-12-15 17:57:24 | 显示全部楼层
我用HASS.IO + homebridge 把小米网关挂到了HomeKit上,可以正常控制网关灯,今天新增了一个小米零火单键开关,在小米的米家APP下可以正常使用。但在HomeKit上无法识别到这个新增开关。
挂在小米网关下的设备在HomeKit是不是可以真接使用呢?还是得再设置什么呢?
 楼主| 发表于 2017-12-15 19:58:09 | 显示全部楼层
configuration.yaml 这里面设置什么吗?
homeassistant:
  # Name of the location where Home Assistant is running
  # 智能家居系统的名字,显示在主界面顶部。
  # Location required to calculate the time the sun rises and sets
  latitude: 24.5133
  longitude: 117.6556
  # 下面填入纬度和经度,计算太阳升起和设定时间所需位置,越精确越好。
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # 海拔高度用于修正天气参数和日出日落时间参数 (默认单位是:米)。
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
  #在网页界面的首页显示简介(那一大段英文),不想看到的话,请在前面加上#号
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
group: !include groups.yaml
script: !include scripts.yaml
# xiaomi gateway 自己的
xiaomi_aqara:
  gateways:
    - mac: 35CE008C060E
      key: E29E6BFD60179588
这是我现在的设置
 楼主| 发表于 2017-12-15 23:00:38 | 显示全部楼层
期待 热心的大神的出现
发表于 2017-12-30 12:24:33 | 显示全部楼层
我最近加了2个86的插座也是找不到,后来请教homebridge-mi-aqara的作者YinHang ,发现是小米做了调整,导致部分产品modle为空,所以无法出现在HK里,等待小米网关的更新吧,或者YinHang用其他方法修复
GMT+8, 2025-8-2 16:16 , Processed in 0.470659 second(s), 12 queries , MemCached On.
