查看: 1963|回复: 1
[求助] esp01s+LD2410B总是报错 请帮忙看看原因
发表于 2023-4-30 00:05:57 | 显示全部楼层 |阅读模式
INFO Reading configuration /config/esphome/ld2410.yaml...
INFO Starting log output from ld2410.local using esphome API
INFO Successfully connected to ld2410.local
[23:57:53][I][app:102]: ESPHome version 2023.4.2 compiled on Apr 29 2023, 23:17:10
[23:57:54][C][wifi:505]: WiFi:
[23:57:54][C][wifi:363]:   Local MAC:
[23:57:54][C][wifi:364]:   SSID:
[23:57:54][C][wifi:365]:   IP Address:
[23:57:54][C][wifi:366]:   BSSID:
[23:57:54][C][wifi:368]:   Hostname: 'ld2410'
[23:57:54][C][wifi:370]:   Signal strength: -60 dB ▂▄▆█
[23:57:54][C][wifi:374]:   Channel: 1
[23:57:54][C][wifi:375]:   Subnet: 255.255.255.0
[23:57:54][C][wifi:376]:   Gateway: 192.168.1.4
[23:57:54][C][wifi:377]:   DNS1: 223.5.5.5
[23:57:54][C][wifi:378]:   DNS2: 114.114.114.114
[23:57:54][C][logger:294]: Logger:
[23:57:54][C][logger:295]:   Level: DEBUG
[23:57:54][C][logger:296]:   Log Baud Rate: 0
[23:57:54][C][logger:297]:   Hardware UART: UART0
[23:57:54][C][uart.arduino_esp8266:102]: UART Bus:
[23:57:54][C][uart.arduino_esp8266:103]:   TX Pin: GPIO1
[23:57:54][C][uart.arduino_esp8266:104]:   RX Pin: GPIO3
[23:57:54][C][uart.arduino_esp8266:106]:   RX Buffer Size: 256
[23:57:54][C][uart.arduino_esp8266:108]:   Baud Rate: 256000 baud
[23:57:54][C][uart.arduino_esp8266:109]:   Data Bits: 8
[23:57:54][C][uart.arduino_esp8266:110]:   Parity: NONE
[23:57:54][C][uart.arduino_esp8266:111]:   Stop bits: 1
[23:57:54][C][uart.arduino_esp8266:113]:   Using hardware serial interface.
[23:57:54][C][ld2410:012]: LD2410:
[23:57:54][C][ld2410:014]:   HasTargetSensor 'has_target'
[23:57:54][C][ld2410:014]:     Device Class: 'occupancy'
[23:57:54][C][ld2410:015]:   MovingSensor 'has_moving_target'
[23:57:54][C][ld2410:015]:     Device Class: 'motion'
[23:57:54][C][ld2410:016]:   StillSensor 'has_still_target'
[23:57:54][C][ld2410:016]:     Device Class: 'occupancy'
[23:57:54][C][ld2410:019]:   Moving Distance 'moving_distance'
[23:57:54][C][ld2410:019]:     Device Class: 'distance'
[23:57:54][C][ld2410:019]:     State Class: ''
[23:57:54][C][ld2410:019]:     Unit of Measurement: 'cm'
[23:57:54][C][ld2410:019]:     Accuracy Decimals: 0
[23:57:54][C][ld2410:020]:   Still Distance 'still_distance'
[23:57:54][C][ld2410:020]:     Device Class: 'distance'
[23:57:54][C][ld2410:020]:     State Class: ''
[23:57:54][C][ld2410:020]:     Unit of Measurement: 'cm'
[23:57:54][C][ld2410:020]:     Accuracy Decimals: 0
[23:57:54][C][ld2410:021]:   Moving Energy 'moving_energy'
[23:57:54][C][ld2410:021]:     Device Class: 'energy'
[23:57:54][C][ld2410:021]:     State Class: ''
[23:57:54][C][ld2410:021]:     Unit of Measurement: '%'
[23:57:54][C][ld2410:021]:     Accuracy Decimals: 0
[23:57:54][C][ld2410:028]:   Firmware Version : 0.0.0000
[23:57:54][E][ld2410:181]: Error with last command : status != 0x01
[23:57:54][C][mdns:108]: mDNS:
[23:57:54][C][mdns:109]:   Hostname: ld2410
[23:57:54][C][ota:093]: Over-The-Air Updates:
[23:57:54][C][ota:094]:   Address: ld2410.local:8266
[23:57:54][C][ota:097]:   Using Password.
[23:57:54][C][api:138]: API Server:
[23:57:54][C][api:139]:   Address: ld2410.local:6053
[23:57:54][C][api:143]:   Using noise encryption: NO
[23:57:54][D][api:102]: Accepted 192.168.1.32
[23:57:54][D][api.connection:961]: Home Assistant 2023.4.6 (192.168.1.32): Connected successfully
[23:58:16][D][api:102]: Accepted 192.168.1.32
[23:58:16][W][api.connection:089]: 192.168.1.32: Reading failed: BAD_INDICATOR errno=11
[23:59:16][D][api:102]: Accepted 192.168.1.32
[23:59:16][W][api.connection:089]: 192.168.1.32: Reading failed: BAD_INDICATOR errno=11
[00:00:16][D][api:102]: Accepted 192.168.1.32
[00:00:16][W][api.connection:089]: 192.168.1.32: Reading failed: BAD_INDICATOR errno=11
[00:01:16][D][api:102]: Accepted 192.168.1.32
[00:01:16][W][api.connection:089]: 192.168.1.32: Reading failed: BAD_INDICATOR errno=11
3万
发表于 2023-4-30 00:27:34 | 显示全部楼层
https://community.home-assistant ... -3-0-upgrade/550228
使用 api encryption
password (Optional, Deprecated, string): The password to protect the API Server with. Defaults to no password. It is recommended to use the encryption -> key above instead of the the password.
GMT+8, 2025-12-15 23:39 , Processed in 0.130362 second(s), 11 queries , MemCached On.
