查看: 5286|回复: 10
[流程系列] 想用nodered获取unraid管理页的运行状态,动态数值不显示
发表于 2023-4-28 09:20:54 | 显示全部楼层 |阅读模式
如题,望大神指点迷津,本人小白貌似动态变化的数据不能提取出来,还是要用其他方法才可以
[{"id":"f4a4d8eab7935bc8","type":"tab","label":"http提取","disabled":false,"info":"","env":[]},{"id":"8fda19f834112fef","type":"inject","z":"f4a4d8eab7935bc8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":60,"wires":[["8afab7260ed71bf5"]]},{"id":"faecfbd893d3fc49","type":"debug","z":"f4a4d8eab7935bc8","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":260,"y":440,"wires":[]},{"id":"8afab7260ed71bf5","type":"http request","z":"f4a4d8eab7935bc8","name":"","method":"GET","ret":"txt","paytoqs":"ignore","url":"https://unraid.123456.xyz/Dashboard","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"other","keyValue":"cookie","valueType":"other","valueValue":"vmsettings_view_mode=basic; ca_startupButton=onlynew; ca_selectedMenu=onlynew; diskio=diskio; sys_view=sys_view; enter_view=3; nerdtools_checkall=no; nerdtools_packages_uninstall=--uninstall; netline=120; cpuline=120; my_apps=startedOnly; my_vms=startedOnly; db-box3=; db-box1=_system_information_%3Bmotherboard%3Bprocessorin%3Bfaninformat%3Bmemoryutili%3Binterfacein; port_select=eth0; db-box2=docker%E5%AE%B9%E5%99%A8%3B%E8%99%9A%E6%8B%9F%E6%9C%BA%3Barrayinform%3Bsharesinfor%3Busersinform%3Bparityinfor%3Bcacheinform; docker_listview_mode=basic; unraid_5f4472a47da050b64c430638add2a19f=d2b9853225225b042f1d24088439d72a"}],"x":280,"y":80,"wires":[["966d3d5b9e60634b","b42e8550eb9ad935"]]},{"id":"966d3d5b9e60634b","type":"html","z":"f4a4d8eab7935bc8","name":"","property":"payload","outproperty":"payload","tag":"#db-box1 > tbody:nth-child(3) > tr:nth-child(3) > td","ret":"text","as":"multi","x":270,"y":180,"wires":[["faecfbd893d3fc49"]]},{"id":"b42e8550eb9ad935","type":"html","z":"f4a4d8eab7935bc8","name":"","property":"payload","outproperty":"payload","tag":"#db-box1 > tbody:nth-child(3) > tr:nth-child(1) > td > div","ret":"html","as":"single","x":260,"y":280,"wires":[["faecfbd893d3fc49"]]}]
发表于 2023-4-28 15:47:30 | 显示全部楼层
用python
发表于 2023-4-28 17:15:23 | 显示全部楼层
数据单独通过API异步返回,你这个URL抓取的只是HTML静态资源,你需要找到查询数据接口,请求接口才能获取真实数据。
 楼主| 发表于 2023-4-28 17:25:26 | 显示全部楼层
xiaohuoya888 发表于 2023-4-28 17:15
数据单独通过API异步返回,你这个URL抓取的只是HTML静态资源,你需要找到查询数据接口,请求接口才能获取真 ...
不知具体如何操作,有相关保姆教程吗
 楼主| 发表于 2023-4-28 18:01:56 | 显示全部楼层
小白一下搞复杂了
发表于 2023-4-29 09:54:25 | 显示全部楼层
我打不开网页  https://unraid.123456.xyz/Dashboard
发表于 2023-4-29 11:54:29 | 显示全部楼层
抓包分析分析呗
若然,一切若然~
发表于 2023-4-29 13:26:47 | 显示全部楼层
好像unraid有个hass用的API插件。在APP里面搜得到
 楼主| 发表于 2023-4-29 20:00:11 | 显示全部楼层
感谢提醒,在尝试操作一下
 楼主| 发表于 2023-4-29 20:01:16 | 显示全部楼层
ylilike 发表于 2023-4-29 11:54
抓包分析分析呗
搞复杂了
GMT+8, 2025-12-17 13:49 , Processed in 0.828654 second(s), 11 queries , MemCached On.
