查看: 1590|回复: 0
[求助] 登录无法登录xiaomi MIoT和xiaomi Miot Auto报错
发表于 2023-4-27 11:31:16 | 显示全部楼层 |阅读模式
登录xiaomi  MIoT和xiaomi Miot Auto报错:
此错误来自自定义集成。
Logger: custom_components.xiaomi_miot.config_flow
Source: custom_components/xiaomi_miot/config_flow.py:301
Integration: Xiaomi Miot Auto (documentation, issues)
First occurred: 11:07:53 (3 occurrences)
Last logged: 11:26:04
Setup xiaomi cloud for user: 13xxxxxxxxx failed: HTTPSConnectionPool(host='account.xiaomi.com', port=443): Max retries exceeded with url: /pass/serviceLogin?sid=xiaomiio&_json=true (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f0c61298550>: Failed to establish a new connection: [Errno -3] Try again'))
Setup xiaomi cloud for user: 13xxxxxxxxx  failed: HTTPSConnectionPool(host='sts.api.io.mi.com', port=443): Max retries exceeded with url: /sts?d=JRBZPS03PCI22KE7&ticket=0&pwd=1&p_ts=1682565341000&fid=0&p_lm=1&auth=lS05FhIABmmE4s37dQt6kMWblpiIi0TOUdkwyOvQ8lLueAYzkAyPcpvXdP7asLNoPczQ6pPjSjMicv3MfYSTglhDCHRFqWKM1y%2FEp2dOtXEUdVJwgraOan0ZV%2BuTeGJvoZ8zOy9vB3fuA2y9w6VC5CLYxBQsxAPyR1OE%2FE542yA%3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=CN&p_idc=China&nonce=p2x97ZtrrI4Bq%2BYD&_ssign=7EHb6ANk%2Fmf6bk9y5w73vQcb%2FJI%3D (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f0c54404e20>: Failed to establish a new connection: [Errno -3] Try again'))
Setup xiaomi cloud for user: 1313xxxxxxxxx  failed: HTTPSConnectionPool(host='account.xiaomi.com', port=443): Max retries exceeded with url: /pass/serviceLogin?sid=xiaomiio&_json=true (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f0c544062c0>: Failed to establish a new connection: [Errno -3] Try again'))
GMT+8, 2025-12-16 19:59 , Processed in 0.106898 second(s), 12 queries , MemCached On.
