查看: 5162|回复: 1
[技术探讨] 重启复位后无法访问。有日志
发表于 2017-12-14 08:58:13 | 显示全部楼层 |阅读模式
刚安装完是可以访问的。
修改设置在重启服务就不能访问了。下面是日志。
帮忙看一下。谢谢
$ sudo journalctl -u [email protected] -f
-- Logs begin at 三 2017-12-13 20:32:55 CST. --
12月 14 08:54:13 kingmacth-HomeAssistant hass[9699]: INFO:homeassistant.core:Starting Home Assistant core loop
12月 14 08:54:13 kingmacth-HomeAssistant hass[9699]: INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
12月 14 08:54:13 kingmacth-HomeAssistant hass[9699]: INFO:homeassistant.core:Timer:starting
12月 14 08:54:27 kingmacth-HomeAssistant hass[9699]: WARNING:netdisco.ssdp:Error fetching description at http://192.168.1.100:49153/nasdevice.xml
12月 14 08:54:30 kingmacth-HomeAssistant hass[9699]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sun.sun=above_horizon; next_dawn=2017-12-14T23:26:55+00:00, next_setting=2017-12-14T10:03:42+00:00, next_noon=2017-12-14T04:58:15+00:00, next_dusk=2017-12-14T10:30:14+00:00, azimuth=125.14, next_midnight=2017-12-14T16:58:51+00:00, friendly_name=Sun, next_rising=2017-12-14T23:53:28+00:00, elevation=10.56 @ 2017-12-14T08:54:08.930706+08:00>, new_state=<state sun.sun=above_horizon; next_dawn=2017-12-14T23:26:55+00:00, next_setting=2017-12-14T10:03:42+00:00, next_noon=2017-12-14T04:58:15+00:00, next_dusk=2017-12-14T10:30:14+00:00, azimuth=125.19, next_midnight=2017-12-14T16:58:51+00:00, friendly_name=Sun, next_rising=2017-12-14T23:53:28+00:00, elevation=10.62 @ 2017-12-14T08:54:08.930706+08:00>, entity_id=sun.sun>
12月 14 08:54:34 kingmacth-HomeAssistant hass[9699]: INFO:homeassistant.components.discovery:Unknown service discovered: DLNA {'name': 'MyBookLive-Twonky', 'serial': '5.1.9', 'host': '192.168.1.100', 'ssdp_description': 'http://192.168.1.100:9000/DeviceDescription.xml', 'port': 9000, 'model_number': '5.1.9', 'model_name': 'TwonkyMedia Server'}
12月 14 08:54:34 kingmacth-HomeAssistant hass[9699]: INFO:homeassistant.components.discovery:Unknown service discovered: DLNA {'name': 'kingmacth_DSM', 'serial': 'B3J4N01003', 'host': '192.168.1.108', 'ssdp_description': 'http://192.168.1.108:50001/desc/device.xml', 'port': 50001, 'model_number': None, 'model_name': 'DS3615xs'}
12月 14 08:55:30 kingmacth-HomeAssistant hass[9699]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sun.sun=above_horizon; next_dawn=2017-12-14T23:26:55+00:00, next_setting=2017-12-14T10:03:42+00:00, next_noon=2017-12-14T04:58:15+00:00, next_dusk=2017-12-14T10:30:14+00:00, azimuth=125.19, next_midnight=2017-12-14T16:58:51+00:00, friendly_name=Sun, next_rising=2017-12-14T23:53:28+00:00, elevation=10.62 @ 2017-12-14T08:54:08.930706+08:00>, new_state=<state sun.sun=above_horizon; next_dawn=2017-12-14T23:26:55+00:00, next_setting=2017-12-14T10:03:42+00:00, next_noon=2017-12-14T04:58:15+00:00, next_dusk=2017-12-14T10:30:14+00:00, azimuth=125.34, next_midnight=2017-12-14T16:58:51+00:00, friendly_name=Sun, next_rising=2017-12-14T23:53:28+00:00, elevation=10.8 @ 2017-12-14T08:54:08.930706+08:00>, entity_id=sun.sun>
12月 14 08:56:30 kingmacth-HomeAssistant hass[9699]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sun.sun=above_horizon; next_dawn=2017-12-14T23:26:55+00:00, next_setting=2017-12-14T10:03:42+00:00, next_noon=2017-12-14T04:58:15+00:00, next_dusk=2017-12-14T10:30:14+00:00, azimuth=125.34, next_midnight=2017-12-14T16:58:51+00:00, friendly_name=Sun, next_rising=2017-12-14T23:53:28+00:00, elevation=10.8 @ 2017-12-14T08:54:08.930706+08:00>, new_state=<state sun.sun=above_horizon; next_dawn=2017-12-14T23:26:55+00:00, next_setting=2017-12-14T10:03:42+00:00, next_noon=2017-12-14T04:58:15+00:00, next_dusk=2017-12-14T10:30:14+00:00, azimuth=125.49, next_midnight=2017-12-14T16:58:51+00:00, friendly_name=Sun, next_rising=2017-12-14T23:53:28+00:00, elevation=10.97 @ 2017-12-14T08:54:08.930706+08:00>, entity_id=sun.sun>
 楼主| 发表于 2017-12-14 10:11:18 | 显示全部楼层
嚓。原来是修改密码的时候少了一个空格。冒号后要用空格再输密码。
GMT+8, 2025-8-13 07:40 , Processed in 0.364909 second(s), 6 queries , MemCached On.
