查看: 9236|回复: 18
[经验分享] 鸿雁6键场景面板脚本
发表于 2023-4-19 23:07:42 | 显示全部楼层 |阅读模式
偶然看到某鱼上便宜的鸿雁6键液晶场景面板,使用了一段时间,稳定可靠,找了HA官网论坛,没有这个面板的Blueprints脚本,于是简单写了一个,方便大家使用面板如图:
Blueprints脚本如下:
blueprint:
  name: Z2M - 6-Button Scene Switch U86KCJ-ZP
  description: 'Control anything using the 6-button scene switch U86KCJ-ZP
    Inspired by the blueprint of @bouyssic (https://www.zigbee2mqtt.io/devices/U86KCJ-ZP.html)'
  domain: automation
  input:
    switch:
      name: 6-button scene switch
      description: 6-button scene switch to use (by model U86KCJ-ZP)
      selector:
        entity:
          domain: sensor
          integration: mqtt
          multiple: false
    button_1_single:
      name: Scene Switch 1 Button - Single Click
      description: Action to run after single click of scenery 1 button
      default: []
      selector:
        action: {}
    button_2_single:
      name: Scene Switch 2 Button - Single Click
      description: Action to run after single click of scenery 2 button
      default: []
      selector:
        action: {}
    button_3_single:
      name: Scene Switch 3 Button -  Single Click
      description: Action to run after single click of scenery 3 button
      default: []
      selector:
        action: {}
    button_4_single:
      name: Scene Switch 4 Button - Single Click
      description: Action to run after single click of scenery 4 button
      default: []
      selector:
        action: {}
    button_5_single:
      name: Scene Switch 5 Button - Single Click
      description: Action to run after single click of scenery 5 button
      default: []
      selector:
        action: {}
    button_6_single:
      name: Scene Switch 6 Button - Single Click
      description: Action to run after single click of scenery 6 button
      default: []
      selector:
        action: {}
  source_url: https://www.zigbee2mqtt.io/devices/U86KCJ-ZP.html
mode: single
max_exceeded: silent
trigger:
- platform: state
  entity_id: !input switch
  attribute: action
action:
- variables:
    command: '{{ trigger.to_state.state }}'
- choose:
  - conditions:
    - '{{ command == ''scene_1'' }}'
    sequence: !input button_1_single
  - conditions:
    - '{{ command == ''scene_2'' }}'
    sequence: !input button_2_single
  - conditions:
    - '{{ command == ''scene_3'' }}'
    sequence: !input button_3_single
  - conditions:
    - '{{ command == ''scene_4'' }}'
    sequence: !input button_4_single
  - conditions:
    - '{{ command == ''scene_5'' }}'
    sequence: !input button_5_single
  - conditions:
    - '{{ command == ''scene_6'' }}'
    sequence: !input button_6_single
Z2M - 6-Button Scene Switch.yaml.zip
1.17 KB, 下载次数: 23
参与人数 3金钱 +17 收起 理由
dajin99 + 5 墙都不扶,就服楼主!
SandLabs + 2 感谢楼主分享!
隔壁的王叔叔 + 10 高手,这是高手!
发表于 2023-4-22 23:03:26 | 显示全部楼层
大佬你好 小白想请教下 我这边开发商交付配套的鸿雁灯具开关 包括你图里这种场景开关有两个 以及一个zigbee的网关,想把开关都接入到HA 我按照网关二维码扫出来的说明书下载了app但是搜不到网关 设置不了和HA同网段 该从哪里下手解决呀?
 楼主| 发表于 2023-4-23 11:13:49 | 显示全部楼层
首先,使用这个自动化蓝图脚本,需要使用zigbee2mqtt;其次,不确定鸿雁的其他设备是否支持zigbee2mqtt;l另外,对于zigbee2mqtt支持的设备请查看:https://www.zigbee2mqtt.io/supported-devices/
HA是可以支持多个zigbee2mqtt(LAN接口或WiFi,不能使用USB端口的)来支持大户型或别墅部署
发表于 2023-4-23 13:10:17 | 显示全部楼层
感谢分享。
发表于 2023-4-26 21:48:51 | 显示全部楼层
alex950418 发表于 2023-4-23 11:13
首先,使用这个自动化蓝图脚本,需要使用zigbee2mqtt;其次,不确定鸿雁的其他设备是否支持zigbee2mqtt;l ...
谢谢 我查到了 Honyar U86K31ND 是支持的,硬件准备我还需要去搞一个zibgee2MQTT的网关对吧?
发表于 2023-4-28 09:05:47 | 显示全部楼层
我正想买一个这个面板,就有大佬来分享!赞啊!
发表于 2023-5-3 08:42:50 | 显示全部楼层
问一下大佬,这个蓝图脚本如何使用啊?HA里的蓝图是让添加网址。是直接创建脚本,贴上代码吗?@alex950418
 楼主| 发表于 2023-5-3 18:17:34 | 显示全部楼层
HA配置目录有个文件夹:blueprints,下载*.yaml文件到这个目录,回到HA管理页面,直接就可以用了
发表于 2023-5-3 20:47:31 | 显示全部楼层
谢谢大咖成果分享,面板价格多少?
发表于 2023-5-3 22:36:41 | 显示全部楼层
alex950418 发表于 2023-5-3 18:17
HA配置目录有个文件夹:blueprints,下载*.yaml文件到这个目录,回到HA管理页面,直接就可以用了 ...
好的,谢谢啦!
GMT+8, 2026-1-14 06:02 , Processed in 1.156246 second(s), 11 queries , MemCached On.
