查看: 2947|回复: 5
[已解决] esphome求大神帮忙时间组件设置晚上17点自动开启早上6点关闭
发表于 2023-4-18 00:18:01 | 显示全部楼层 |阅读模式
<blockquote>esphome:
我这边可能是网络问题,ESP接入hass经常掉线,用MQTT也掉,所以有些打算用时间控制开关,自己捣鼓一会实在搞不定,不知道哪里出问题。麻烦你们了。谢谢
 楼主| 发表于 2023-4-18 00:21:30 | 显示全部楼层
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "1"
wifi:
  ssid: "99996"
  password: ""
  ap:
    ssid: "ss"
    password: "12345678"
web_server:
  port: 80
captive_portal:
switch:
  - platform: gpio
    pin: GPIO0
    restore_mode: RESTORE_DEFAULT_OFF
time:
  - platform: sntp #NTP时间
    servers: ntp5.aliyun.com #NTP服务器地址
    timezone: UTC-8 #中国时区
    on_time:
      - seconds: 0
        minutes: 0
        hours: 17
        days_of_week: MON-FRI
        then:
          - switch.turn_on: relay1
      # Every morning on weekdays
      - seconds: 0
        minutes: 0
        hours: 6
        then:
          - switch.turn_off: relay1
on_...:
  if:
    condition:
      time.has_time:
    then:
      - logger.log: Time has been set and is valid!
# Example lambda
lambda: |-
    if (id(my_time).now().is_valid()) {
      //do something here
 楼主| 发表于 2023-4-18 00:39:38 | 显示全部楼层
这是第二个代码也不行  老错误
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "your_wifi_ssid"
  password: "your_wifi_password"
# Enable logging
logger:
api:
# Enable OTA updates
ota:
time:
  - platform: homeassistant
# Schedule the switch to turn on at 5pm and off at 6am
time:
  - platform: sntp
    timezone: Asia/Shanghai
    servers:
      - cn.pool.ntp.org
  - platform: template
    name: "Switch On Time"
    lambda: |-
      return id(homeassistant_time).now().hour == 17 && id(homeassistant_time).now().minute == 0 && id(homeassistant_time).now().second == 0;
    name: "Switch Off Time"
    lambda: |-
      return id(homeassistant_time).now().hour == 6 && id(homeassistant_time).now().minute == 0 && id(homeassistant_time).now().second == 0;
switch:
  - platform: gpio
    pin: GPIO0
# Turn on the switch at 5pm and off at 6am
automation:
  - id: switch_on_automation
    alias: "Switch On"
    trigger:
      platform: time
    action:
      - switch.turn_on: switch_pin
  - id: switch_off_automation
    alias: "Switch Off"
    trigger:
      platform: time
    action:
      - switch.turn_off: switch_pin
发表于 2023-4-18 02:37:47 来自手机 | 显示全部楼层
既然你这是接入HA使用,干脆用scheduler-component和scheduler-card配合来控制开关,功能上更加通用灵活。
发表于 2023-4-18 08:47:12 | 显示全部楼层
第一个去掉id: on、id: off和最后两段
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
api:
ota:
  password: "1"
wifi:
  ssid: "99996"
  password: ""
  ap:
    ssid: "ss"
web_server:
  port: 80
captive_portal:
switch:
  - platform: gpio
    pin: GPIO0
time:
    on_time:
      - seconds: 0
        minutes: 0
        hours: 17
        then:
      - seconds: 0
        minutes: 0
        hours: 6
        then:
 楼主| 发表于 2023-4-18 19:45:31 | 显示全部楼层
原来如此  谢谢
GMT+8, 2025-12-30 04:42 , Processed in 0.398667 second(s), 8 queries , MemCached On.
