查看: 6701|回复: 4
[求助] 感应开灯自动化,每晚0点后都会故障,求大神帮忙看看
发表于 2017-12-10 19:57:20 | 显示全部楼层 |阅读模式
我设置了2对自动化,分别是有人移动时开灯和无人后15秒关灯。但是每当0点以后,这两对自动化都会失效,以下是日志中的报错信息,但我看不懂是什么原因,请大神帮忙解答一下,谢谢了。
2017-12-10 00:36:51 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
OSError: [Errno 113] Host is unreachable
2017-12-10 02:59:40 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
    raise err
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 357, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/lib/python3.6/http/client.py", line 1239, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1285, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1234, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1026, in _send_output
    self.send(msg)
  File "/usr/lib/python3.6/http/client.py", line 964, in send
    self.connect()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 166, in connect
    conn = self._new_conn()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x73f90a90>: Failed to establish a new connection: [Errno 111] Connection refused
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.31.1', port=80): Max retries exceeded with url: /cgi-bin/luci/;stok=edcf46bedc5265865bfcd78d35381e08/api/misystem/devicelist (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73f90a90>: Failed to establish a new connection: [Errno 111] Connection refused',))
  File "/usr/lib/python3.6/asyncio/tasks.py", line 181, in _step
    result = coro.throw(exc)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 699, in async_device_tracker_scan
    found_devices = yield from scanner.async_scan_devices()
  File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
    future.result()
  File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
    raise self._exception
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/xiaomi.py", line 53, in scan_devices
    self._update_info()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/xiaomi.py", line 79, in _update_info
    result = self._retrieve_list_with_retry()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/xiaomi.py", line 91, in _retrieve_list_with_retry
    result = _retrieve_list(self.host, self.token)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/xiaomi.py", line 113, in _retrieve_list
    res = requests.get(url, timeout=5, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.31.1', port=80): Max retries exceeded with url: /cgi-bin/luci/;stok=edcf46bedc5265865bfcd78d35381e08/api/misystem/devicelist (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73f90a90>: Failed to establish a new connection: [Errno 111] Connection refused',))
发表于 2017-12-10 20:45:59 | 显示全部楼层
你的路由器,是不是设置了每天晚上0点重启?
 楼主| 发表于 2017-12-10 22:26:02 | 显示全部楼层
不是。 我设置的是每天3:00重启。
发表于 2017-12-10 23:31:03 | 显示全部楼层
路由器有沒有設00:00後網路關閉?
看log是說連不到設備
 楼主| 发表于 2017-12-11 10:16:22 | 显示全部楼层
windgo 发表于 2017-12-10 23:31
路由器有沒有設00:00後網路關閉?
看log是說連不到設備
没有设置网络断开。
GMT+8, 2025-12-25 13:57 , Processed in 0.597853 second(s), 19 queries , MemCached On.
