查看: 2676|回复: 2
[求助] 通过mqqt 定义的空调卡片不可用 ,不知道哪里的问题
发表于 2023-4-5 22:39:31 | 显示全部楼层 |阅读模式
 climate:
      - unique_id: rilikongtiao1
        modes:
          - "off"
          - "heat"
          - "dry"
          - "cool"
          - "fan_only"
        fan_modes:
          - "high"
          - "medium"
          - "low"
          - "auto"
          - "silent"
        power_command_topic: "homeassistant/climate/zhonghong/ac_0_4/power/set"
        mode_command_topic: "homeassistant/climate/zhonghong/ac_0_4/mode/set"
        current_temperature_topic: "homeassistant/climate/zhonghong/ac_0_4/cur_temp/state"
        mode_state_topic: "homeassistant/climate/zhonghong/ac_0_4/mode/state"
        temperature_command_topic: "homeassistant/climate/zhonghong/ac_0_4/temp/set"
        temperature_state_topic: "homeassistant/climate/zhonghong/ac_0_4/temp/state"
        fan_mode_command_topic: "homeassistant/climate/zhonghong/ac_0_4/fan/set"
        fan_mode_state_topic: "homeassistant/climate/zhonghong/ac_0_4/fan/state"
发表于 2023-4-6 14:59:02 | 显示全部楼层
网上好多例子都是旧版写法。参考官方的吧:MQTT HVAC
mqtt:
  climate:
    - name: rilikongtiao1
      modes:
        - "off"
        - "heat"
        - "dry"
        - "cool"
        - "fan_only"
      fan_modes:
        - "high"
        - "medium"
        - "low"
        - "auto"
        - "silent"
      mode_state_topic: "homeassistant/climate/zhonghong/ac_0_0/mode/state"
      temperature_command_topic: "homeassistant/climate/zhonghong/ac_0_0/temp/set"
      temperature_state_topic: "homeassistant/climate/zhonghong/ac_0_0/temp/state"
      precision: 1.0
      min_temp: 16
      max_temp: 30
 楼主| 发表于 2023-4-8 22:59:57 | 显示全部楼层
谢谢 已经可以了 但现在发现风速控制不了
GMT+8, 2025-12-17 14:07 , Processed in 1.039916 second(s), 8 queries , MemCached On.
