楼主: relliky
[修仙教程] 【设备多怎么办】以房间为单位写易维护的配置代码
 火.. [复制链接]
发表于 2023-4-9 19:44:36 | 显示全部楼层
厉害,谢谢分享,mark
发表于 2023-4-10 22:04:23 | 显示全部楼层
如何写配置教程
发表于 2023-4-11 11:18:45 | 显示全部楼层
不明觉厉!!
 楼主| 发表于 2023-4-11 17:29:40 | 显示全部楼层
W@LTER 发表于 2023-4-4 17:15
有人做小白教程吗? 没想到怎么用
不好意思,现阶段我只能做到功能展示。我还没有完善到可以有使用教程的地步。等明年我应该可以做到有配置教程了
wjx 手机认证
发表于 2023-4-13 21:51:24 | 显示全部楼层
学习一下
发表于 2023-4-15 16:30:55 | 显示全部楼层
大佬妞碧。看到那张自动化的图,我还是NR连连看吧。
 楼主| 发表于 2023-4-15 17:15:42 | 显示全部楼层
因为用的函数,其实每个部分都抽象化了,生成的yaml重复代码很多。python的实际代码都挺简单的。
    self.automations += [{
        "alias" : "ZL-" + self.automation_room_name + "Applies Different Scenes Based on Scene Selections (State Execution)" + "-" + self.room_name,
        "configured": self.cfg_scene,
        "trigger": [
            "platform": "state",
            "entity_id": self.room_scene_ctl,
        "mode":"restart", # using restart to improve responsiveness of a scene execution
        "action": [
            "choose": [
              self.callSceneServiceIfSelected("All White"),
              self.callSceneServiceIfSelected("Ceiling Light White"),
              self.callSceneServiceIfSelected("Lamp LED White"),
              self.callSceneServiceIfSelected("LED White"),
              self.callSceneServiceIfSelected("Hue"),
              self.callSceneServiceIfSelected("Night Mode"),
              self.callSceneServiceIfSelected("Dark Night Mode"),
              self.callSceneServiceIfSelected("All Off"),
              self.callSceneServiceIfSelected("Lights on in hot sunshine"),
              self.callSceneServiceIfSelected("Lights on when bright outdoor"),
              self.callSceneServiceIfSelected("Lights on when dark outdoor")
callSceneServiceIfSelected 再调用具体的callSceneService的实现。
  def callSceneService(self, scene_name):
      parallel_enable = True
      scene_service = []
      if   scene_name == 'All White':
          scene_service += [self.turn(self.lamps, "on"),
                            self.turn(self.ceiling_lights, "on"),
                            self.turn(self.leds, "on"),
                            self.turn(self.tvs, tv_brightness=3)]
      elif scene_name == 'Ceiling Light White':
          scene_service += [self.turn(self.leds + self.lamps, "off"),
      #elif scene_name == 'Ceiling Light White with Curtain Open':
      #    scene_service += [self.turn(self.leds + self.lamps, "off"),
      #                      self.turn(self.ceiling_lights, "on"),
      #                      self.turn(self.tvs, tv_brightness=3),
      #                      self.turn(self.curtains, 'on')]
      elif scene_name == 'Lamp LED White':
          scene_service += [self.turn(self.ceiling_lights, "off"),
      elif scene_name == 'LED White':
                            self.turn(self.lamps, "off"),
                            self.turn(self.tvs, tv_brightness=2)]
      elif scene_name == 'Hue':
          parallel_enable = False
          scene_service += [# turn on lights to let adaptive lighting run
                            self.turn(self.lamps + self.leds, "on"),
                            # overwrite adaptive lighting brightiness and set it to max
                            self.turn(self.lamps + self.leds, "on", light_brightness=100),
                            # apply colours
                            { "service" : "pyscript.set_rgb_light_list",
                              "data": {"light_list": self.lamps + self.ceiling_lights+ self.leds}},
      elif scene_name == 'Night Mode':
          scene_service += [{ "service": "homeassistant.turn_on",
                              "entity_id": "scene." + self.room_entity + "_night_mode" },
      elif scene_name == 'Dark Night Mode':
                              "entity_id": "scene." + self.room_entity + "_dark_night_mode" },
                            self.turn(self.tvs, tv_brightness=1)]
      elif scene_name == 'All Off':
                            self.turn(self.leds, "off")]
      elif scene_name in ['Lights on in hot sunshine',
                          'Lights on when bright outdoor',
                          'Lights on when dark outdoor']:
        scene_service += [{"parallel":[
          {"if": self.continueIf(self.ceiling_light_control_when[scene_name], "on"), "then": self.turn(self.ceiling_lights, "on")},
          {"if": self.continueIf(self.lamp_control_when[scene_name]         , "on"), "then": self.turn(self.lamps,          "on")},
          {"if": self.continueIf(self.led_control_when[scene_name]          , "on"), "then": self.turn(self.leds,           "on")},
          {"if": self.continueIf(self.curtain_control_when[scene_name]      , "on"), "then": self.turn(self.curtains,       "on")}
      else:
        raise TypeError( "\n" +\
                         "@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@\n" + \
                         "Scene " + scene_name + " is not supported." + "\n" + \
                         "@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@\n")
      if parallel_enable == True:
        scene_service = [{"parallel":scene_service}]
      # Convert to a single service/entry instead of a list
      return self.convertToSingleService(scene_service, alias=scene_name)
代码的复杂度可以自行扩展
发表于 2023-4-17 13:32:16 | 显示全部楼层
在下对你的景仰犹如滔滔长江之水,连绵不绝.
发表于 2023-4-18 09:32:54 | 显示全部楼层
厉害了。
 楼主| 发表于 2023-4-22 21:34:59 | 显示全部楼层
hackyjso 发表于 2023-4-4 10:37
看不懂但是感觉很牛的样子,
刚刚终于把基本原理部分更新完啦,如果哪还有看不懂我再改进一下
GMT+8, 2026-1-16 06:18 , Processed in 0.784689 second(s), 13 queries , MemCached On.
