查看: 3087|回复: 1
[技术探讨] configuration文件中两个开关就报错的问题
发表于 2023-4-3 23:30:01 | 显示全部楼层 |阅读模式
请教各位大佬,纯小白,论坛抄了两个开关。单独用都好用,但是都放到configurantion中,就报错,求助。
switch:
#远程唤醒家里PC电脑开关
  - platform: wake_on_lan
    mac: "xxxxxx"
    host: xxxxx
    turn_off:
       service: shell_command.turn_off_pc
shell_command:
    turn_off_pc: 'curl -X GET http://xxxxxxxxxx:5001/?action=System.sleep'
#Apple TV的开关
  - platform: template
    switches:
      appletv:
        unique_id: my_unique_id
        friendly_name: "Apple Tv"
        value_template: "{{ is_state('media_player.wo_shi', ['playing','idle']) }}"
        turn_on:
          service: remote.send_command
          data:
            command: wakeup
          target:
            entity_id: remote.wo_shi
        turn_off:
          service: media_player.turn_off
          target:
            entity_id: media_player.wo_shi
          data: {}
提示配置无效:
Error loading /config/configuration.yaml: while parsing a block mappingin "/config/configuration.yaml", line 3, column 1expected <block end>, but found '<block sequence start>'in "/config/configuration.yaml", line 35, column 3
发表于 2023-4-4 05:55:27 | 显示全部楼层
shell_command:
#Apple TV的开关
    switches:
      appletv:
这里是错的,shell_command不能作为它的种类
见官方文档https://www.home-assistant.io/integrations/switch.template/
调换一下就好了
switch:
#远程唤醒家里PC电脑开关
    mac: "xxxxxx"
    host: xxxxx
    turn_off:
#Apple TV的开关
    switches:
      appletv:
        turn_on:
          data:
            command: wakeup
          target:
        turn_off:
          target:
          data: {}
shell_command:
GMT+8, 2026-1-17 10:07 , Processed in 0.267754 second(s), 12 queries , MemCached On.
