查看: 5021|回复: 14
[求助] ztc1接入ha 无法正常显示控制(经过站内大神指导,已解决)
发表于 2023-3-31 18:18:05 | 显示全部楼层 |阅读模式
mqtt:
    switch:
      - name: 'ztc1_1_d0bae464159a'
        unique_id: ztc1_1_d0bae464159a
        state_topic: 'device/ztc1/d0bae464159a/state'
        command_topic: 'device/ztc1/d0bae464159a/set'
        payload_on: '{"mac":"d0bae464159a","plug_0":{"on":1}}'
        payload_off: '{"mac":"d0bae464159a","plug_0":{"on":0}}'
        value_template: '{{ value_json.plug_0.on }}'
        state_on: '1'
        state_off: '0'
    switch:
      - name: 'ztc1_2_d0bae464159a'
        unique_id: ztc1_2_d0bae464159a
        payload_on: '{"mac":"d0bae464159a","plug_1":{"on":1}}'
        payload_off: '{"mac":"d0bae464159a","plug_1":{"on":0}}'
        value_template: '{{ value_json.plug_1.on }}'
        state_on: '1'
        state_off: '0'
    switch:
      - name: 'ztc1_3_d0bae464159a'
        unique_id: ztc1_3_d0bae464159a
        payload_on: '{"mac":"d0bae464159a","plug_2":{"on":1}}'
        payload_off: '{"mac":"d0bae464159a","plug_2":{"on":0}}'
        value_template: '{{ value_json.plug_2.on }}'
        state_on: '1'
        state_off: '0'
    switch:
      - name: 'ztc1_4_d0bae464159a'
        unique_id: ztc1_4_d0bae464159a
        payload_on: '{"mac":"d0bae464159a","plug_3":{"on":1}}'
        payload_off: '{"mac":"d0bae464159a","plug_3":{"on":0}}'
        value_template: '{{ value_json.plug_3.on }}'
        state_on: '1'
        state_off: '0'
    switch:
      - name: 'ztc1_5_d0bae464159a'
        unique_id: ztc1_5_d0bae464159a
        payload_on: '{"mac":"d0bae464159a","plug_4":{"on":1}}'
        payload_off: '{"mac":"d0bae464159a","plug_4":{"on":0}}'
        value_template: '{{ value_json.plug_4.on }}'
        state_on: '1'
        state_off: '0'
    switch:
      - name: 'ztc1_6_d0bae464159a'
        unique_id: ztc1_6_d0bae464159a
        payload_on: '{"mac":"d0bae464159a","plug_5":{"on":1}}'
        payload_off: '{"mac":"d0bae464159a","plug_5":{"on":0}}'
        value_template: '{{ value_json.plug_5.on }}'
        state_on: '1'
        state_off: '0'
      - name: 'ztc1_power_d0bae464159a'
        unique_id: ztc1_power_d0bae464159a
        state_topic: 'device/ztc1/d0bae464159a/sensor'
        #unit_of_measurement: 'W'
        icon: 'mdi:gauge'
        value_template: '{{ value_json.power }}'
      - name: 'ztc1_time_d0bae464159a'
        unique_id: ztc1_time_d0bae464159a
        #unit_of_measurement: '秒'
        icon: 'mdi:gauge'
        #value_template: '{{ value_json.total_time }}'
        value_template: >-
          {% set time = value_json.total_time %}
          {% set minutes = ((time % 3600) / 60) | int %}
          {% set hours = ((time % 86400) / 3600) | int %}
          {% set days = (time / 86400) | int %}
          {%- if time < 60 -%}
            <1分钟
          {%- else -%}
            {%- if days > 0 -%}
                {{ days }}天
            {%- endif -%}
            {%- if hours > 0 -%}
                {{ hours }}小时
            {%- endif -%}
            {%- if minutes > 0 -%}
                {{ minutes }}分钟
            {%- endif -%}
          {%- endif -%}
homeassistant:
  customize:
    switch.ztc1_1_d0bae464159a:
      friendly_name: 客厅1
    switch.ztc1_2_d0bae464159a:
      friendly_name: 打印机
    switch.ztc1_3_d0bae464159a:
      friendly_name: 显示器
    switch.ztc1_4_d0bae464159a:
      friendly_name: 电脑主机
    switch.ztc1_5_d0bae464159a:
      friendly_name: 客厅2
    switch.ztc1_6_d0bae464159a:
      friendly_name: 苹果
    sensor.ztc1_power_d0bae464159a:
      friendly_name: zTC1功率
    sensor.ztc1_time_d0bae464159a:
      friendly_name: zTC1运行时间
请哪位大神帮忙看看,为什么按照以上格式,最后只能显示第六个插槽苹果和运行时间两个实体,而且苹果插槽还可以正常控制,运行时间可以正常显示时间。
同样格式再接入一个ztc2,同样只能显示第六个插槽和运行时间,但插槽无法控制,运行时间没有显示时间。
发表于 2023-3-31 18:50:03 | 显示全部楼层
很少用configuration配置,不过印象里以前配置的时候,你填入中文会导致识别异常,经常吞掉一大堆,全英文试试
 楼主| 发表于 2023-3-31 18:54:59 | 显示全部楼层
wdmywm3 发表于 2023-3-31 18:50
很少用configuration配置,不过印象里以前配置的时候,你填入中文会导致识别异常,经常吞掉一大堆,全英文 ...
试过了,把后面带中文的全删了,结果一样,只是中文变成了英文。更新ha之前好好的,一更新就没了,然后又对照新的格式配置,还是不行
发表于 2023-3-31 20:04:43 | 显示全部楼层
写法有点点问题吧,switch应该是这样
mqtt:
    switch:
        state_on: '1'
        state_off: '0'
        state_on: '1'
        state_off: '0'
而不是每个实体前面一个switch吧,sensor也是这样,话说这样写为什么能够正常配置啊,应该会报错才对啊
 楼主| 发表于 2023-3-31 20:23:19 | 显示全部楼层
而不是每个实体前面一个switch吧,sensor也是这样,话说这样写为什么 ...
谢谢大佬 ,还真是这个问题,去掉多余的switch和sensor后全部正常显示了,但是就是第二个ztc1(我命名的ztc2)可以显示实体,但还是无法控制,
 楼主| 发表于 2023-3-31 20:26:51 | 显示全部楼层
mqtt:
    switch:
      - name: 'ztc2_1_d0bae4641822'
        unique_id: ztc2_1_d0bae4641822
        state_topic: 'device/ztc2/d0bae4641822/state'
        command_topic: 'device/ztc2/d0bae4641822/set'
        payload_on: '{"mac":"d0bae4641822","plug_0":{"on":1}}'
        payload_off: '{"mac":"d0bae4641822","plug_0":{"on":0}}'
        state_on: '1'
        state_off: '0'
      - name: 'ztc2_2_d0bae4641822'
        unique_id: ztc2_2_d0bae4641822
        payload_on: '{"mac":"d0bae4641822","plug_1":{"on":1}}'
        payload_off: '{"mac":"d0bae4641822","plug_1":{"on":0}}'
        state_on: '1'
        state_off: '0'
      - name: 'ztc2_3_d0bae4641822'
        unique_id: ztc2_3_d0bae4641822
        payload_on: '{"mac":"d0bae4641822","plug_2":{"on":1}}'
        payload_off: '{"mac":"d0bae4641822","plug_2":{"on":0}}'
        state_on: '1'
        state_off: '0'
      - name: 'ztc2_4_d0bae4641822'
        unique_id: ztc2_4_d0bae4641822
        payload_on: '{"mac":"d0bae4641822","plug_3":{"on":1}}'
        payload_off: '{"mac":"d0bae4641822","plug_3":{"on":0}}'
        state_on: '1'
        state_off: '0'
      - name: 'ztc2_5_d0bae4641822'
        unique_id: ztc2_5_d0bae4641822
        payload_on: '{"mac":"d0bae4641822","plug_4":{"on":1}}'
        payload_off: '{"mac":"d0bae4641822","plug_4":{"on":0}}'
        state_on: '1'
        state_off: '0'
      - name: 'ztc2_6_d0bae4641822'
        unique_id: ztc2_6_d0bae4641822
        payload_on: '{"mac":"d0bae4641822","plug_5":{"on":1}}'
        payload_off: '{"mac":"d0bae4641822","plug_5":{"on":0}}'
        state_on: '1'
        state_off: '0'
      - name: 'ztc2_power_d0bae4641822'
        unique_id: ztc2_power_d0bae4641822
        state_topic: 'device/ztc2/d0bae4641822/sensor'
        icon: 'mdi:gauge'
      - name: 'ztc2_time_d0bae4641822'
        unique_id: ztc2_time_d0bae4641822
        icon: 'mdi:gauge'
        value_template: >-
            <1分钟
          {%- else -%}
            {%- if days > 0 -%}
                {{ days }}天
            {%- endif -%}
                {{ hours }}小时
            {%- endif -%}
                {{ minutes }}分钟
            {%- endif -%}
          {%- endif -%}
homeassistant:
  customize:
    switch.ztc2_1_d0bae4641822:
      friendly_name: 端口1
    switch.ztc2_2_d0bae4641822:
      friendly_name: Onkyo
    switch.ztc2_3_d0bae4641822:
      friendly_name: Oppo
    switch.ztc2_4_d0bae4641822:
      friendly_name: 电视
    switch.ztc2_5_d0bae4641822:
      friendly_name: 低音炮
    switch.ztc2_6_d0bae4641822:
      friendly_name: coreelec
    sensor.ztc2_power_d0bae4641822:
      friendly_name: ztc2功率
    sensor.ztc2_time_d0bae4641822:
      friendly_name: ztc2运行时间
这是我ztc2的配置文件
 楼主| 发表于 2023-3-31 20:41:11 | 显示全部楼层
发表于 2023-4-1 08:41:22 | 显示全部楼层
请参考格式
 楼主| 发表于 2023-4-1 09:13:21 | 显示全部楼层
是的,我nas用docker装的
发表于 2023-4-1 10:42:17 | 显示全部楼层
GMT+8, 2025-12-16 14:49 , Processed in 0.518204 second(s), 5 queries , MemCached On.
