查看: 3164|回复: 2
[求助] ESP01S接433射频模块的问题
发表于 2023-3-30 10:29:32 | 显示全部楼层 |阅读模式
悬赏100金钱未解决
各位大佬,我用esp01s配合继电器控制一个灯带,使用esphome,现在增加随意贴控制的功能,但是433射频模不管是接GPIO2还是3,都接收不到信号,但是这个模块我接到D1开发板上就没问题,哪位大佬指导一下,谢谢。
esphome的yaml文件如下:
esphome:
  friendly_name: dengdai
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "+ykehwOQigMXijMeOAkO1C5DoTHmEyUJ5eNoXnKJ6qQ="
ota:
  password: "8888"
web_server:
  port: 80
wifi:
  ssid: "wifi"
  password: "88888888"
  ap:
    ssid: "dengdai"
captive_portal:
binary_sensor:
  - platform: remote_receiver
    rc_switch_raw:
      code: '110000000010110000101000'
      protocol: 1
    on_press:
      then:
        - switch.toggle: switch_dengdai
    filters:
      - delayed_off: 1000ms
switch:
  - platform: gpio
    pin: GPIO0
remote_receiver:
  pin:
    number: GPIO3
#    inverted: true
    mode:
      input: true
#      pullup: true
  dump:
    - rc_switch
  tolerance: 50%
  filter: 200us
  idle: 4ms
  buffer_size: 1kb
发表于 2023-3-30 16:55:56 | 显示全部楼层
老哥想问一下 怎么写可以把接收433发送到mqtt做自动化呢
 楼主| 发表于 2023-4-1 16:43:31 | 显示全部楼层
论坛有教程,你找一下,就是接收到433的对应信号之后切换传感器状态,根据传感器状态自动化
GMT+8, 2025-12-18 13:46 , Processed in 1.207303 second(s), 10 queries , MemCached On.
