查看: 2264|回复: 0
[求助] 求教zigbee突然打不开了。
limb
发表于 2023-3-26 14:44:43 | 显示全部楼层 |阅读模式
zigbee突然打不开,启动日志如何,不知道何解?Zigbee2MQTT:debug 2023-03-26 14:41:10: Loaded state from file /config/zigbee2mqtt/state.jsonZigbee2MQTT:info  2023-03-26 14:41:10: Logging to console and directory: '/config/zigbee2mqtt/log/2023-03-26.14-41-10' filename: log.txtZigbee2MQTT:debug 2023-03-26 14:41:10: Removing old log directory '/config/zigbee2mqtt/log/2023-03-26.14-32-00'Zigbee2MQTT:info  2023-03-26 14:41:10: Starting Zigbee2MQTT version 1.30.0 (commit #unknown)Zigbee2MQTT:info  2023-03-26 14:41:10: Starting zigbee-herdsman (0.14.89)Zigbee2MQTT:debug 2023-03-26 14:41:10: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/ttyAML2"}}'Zigbee2MQTT:error 2023-03-26 14:41:30: Error while starting zigbee-herdsmanZigbee2MQTT:error 2023-03-26 14:41:30: Failed to start zigbeeZigbee2MQTT:error 2023-03-26 14:41:30: Check https://www.zigbee2mqtt.io/guide ... fails-to-start.html for possible solutionsZigbee2MQTT:error 2023-03-26 14:41:30: Exiting...Zigbee2MQTT:error 2023-03-26 14:41:31: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)    at Zigbee.start (/app/lib/zigbee.ts:58:27)    at Controller.start (/app/lib/controller.ts:101:27)    at start (/app/index.js:107:5)
GMT+8, 2025-12-16 22:23 , Processed in 0.642709 second(s), 11 queries , MemCached On.
