查看: 1742|回复: 2
[求助] esphome风扇挡位
发表于 2023-3-25 20:08:36 | 显示全部楼层 |阅读模式
抄了个大神写的三档的风扇调节,我这边想增加到5档调节,不知道这个代码该怎么改
substitutions:
  device_name: "auto Fan"
  device_name_low: "auto-fan"
  comment: "auto Fan"
  version: "1.0.0"
  speed_low: "30"
  speed_med: "50"
  speed_full: "80"
esphome:
  project:
    version: "${version}"
  on_boot:
    then:
      - delay: 10s
      - fan.turn_on:
          speed: "${speed_low}"
      - delay: 5s
      - fan.turn_on:
          speed: "${speed_full}"
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "12345678"
wifi:
  ssid: 1111  #WiFi SSID
  password:111  #WiFi密码
  ap:
    ssid: "${device_name_low}"
captive_portal:
web_server:
  port: 80
output:
  - platform: esp8266_pwm
    pin: GPIO2    #D4
    frequency: 15000 Hz
fan:
  - platform: speed
    output: pwm_output
    speed_count: 100
number:
  - platform: template
    icon: "mdi:fan"
    lambda: |-
      return id(fan_speed).speed;
    step: 1
    min_value: 20
    max_value: 100
    unit_of_measurement: "%"
    update_interval: 1s
    set_action:
      then:
        - fan.turn_on:
            speed: !lambda "return x;"
        - component.update: fanmode
        - component.update: sensor_fanspeed
select:
    icon: "mdi:fan"
    update_interval: 1s
    lambda: |-
      if(id(fan_speed).speed <= ${speed_low})
        return std::string("Low");
      else if(id(fan_speed).speed == ${speed_med})
        return std::string("Medium");
      else if(id(fan_speed).speed >= ${speed_full})
        return std::string("Full");
      else
        return std::string("Custom");
    set_action:
      then:
        - lambda: |-
            auto call = id(fan_speed).turn_on();
            if(x == "Low")
              call.set_speed(${speed_low});
            else if(x == "Medium")
              call.set_speed(${speed_med});
            else if(x == "Full")
              call.set_speed(${speed_full});
            else
              call.set_speed(id(speed_input).state);
            call.perform();
        - component.update: speed_input
    options:
      - Low
      - Medium
      - Full
      - Custom
button:
    icon: "mdi:fan-speed-1"
    on_press:
      - fan.turn_on:
    icon: "mdi:fan-speed-2"
    on_press:
      - fan.turn_on:
          speed: "${speed_med}"
    icon: "mdi:fan-speed-3"
    on_press:
      - fan.turn_on:
  - platform: restart
    icon: "mdi:fan"
    lambda: |-
    update_interval: 1s
    accuracy_decimals: 0
  - platform: dht
    pin: GPIO4    #D2
    temperature:
      name: "${device_name} Temperature"
    humidity:
      name: "${device_name} Humidity"
    model: AUTO_DETECT
    update_interval: 5s #获取频率
参与人数 1金钱 +20 收起 理由
dscao + 20 感谢楼主分享!
 楼主| 发表于 2023-3-25 20:29:53 | 显示全部楼层
这样改的 不知道对不对
substitutions:
  comment: "auto Fan"
  version: "1.0.0"
  speed_1: "10"
  speed_2: "30"
  speed_3: "50"
  speed_4: "80"
  speed_5: "100"
esphome:
  project:
  on_boot:
    then:
      - delay: 10s
      - fan.turn_on:
          speed: "${speed_1}"
      - delay: 5s
      - fan.turn_on:
          speed: "${speed_5}"
esp8266:
  board: esp01_1m
# Enable logging
logger:
api:
ota:
wifi:
  ap:
captive_portal:
web_server:
  port: 80
output:
    pin: GPIO2    #D4
    frequency: 15000 Hz
fan:
  - platform: speed
    output: pwm_output
    speed_count: 100
number:
    icon: "mdi:fan"
    lambda: |-
    step: 1
    min_value: 10
    max_value: 100
    update_interval: 1s
    set_action:
      then:
        - fan.turn_on:
select:
    icon: "mdi:fan"
    update_interval: 1s
    lambda: |-
      if(id(fan_speed).speed <= ${speed_1})
        return std::string("1");
      else if(id(fan_speed).speed == ${speed_2})
        return std::string("2");
      else if(id(fan_speed).speed >= ${speed_3})
        return std::string("3");
      else if(id(fan_speed).speed == ${speed_4})
        return std::string("4");
      else if(id(fan_speed).speed >= ${speed_5})
        return std::string("5");
      else
    set_action:
      then:
        - lambda: |-
            if(x == "1)
              call.set_speed(${speed_1});
            else if(x == "2")
              call.set_speed(${speed_2});
            else if(x == "3")
              call.set_speed(${speed_3});
            else if(x == "4")
              call.set_speed(${speed_4});
            else if(x == "5")
              call.set_speed(${speed_5});
            else
            call.perform();
    options:
      - 1
      - 2
      - 3
      - 4
      - 5
      - Custom
button:
    on_press:
      - fan.turn_on:
          speed: "${speed_1}"
    on_press:
      - fan.turn_on:
          speed: "${speed_2}"
    on_press:
      - fan.turn_on:
          speed: "${speed_3}"
    icon: "mdi:fan-speed-4"
    on_press:
      - fan.turn_on:
          speed: "${speed_4}"
    icon: "mdi:fan-speed-5"
    on_press:
      - fan.turn_on:
          speed: "${speed_5}"
  - platform: restart
    icon: "mdi:fan"
    lambda: |-
    update_interval: 1s
  - platform: dht
    pin: GPIO4    #D2
    temperature:
    humidity:
    model: AUTO_DETECT
参与人数 1金钱 +10 收起 理由
sorrypqa + 10 大神666!
发表于 2023-3-25 22:46:50 | 显示全部楼层
kaka0992 发表于 2023-3-25 20:29
这样改的 不知道对不对
好复杂,学习一下,谢谢分享!
GMT+8, 2025-12-16 05:16 , Processed in 1.044848 second(s), 8 queries , MemCached On.
