查看: 2524|回复: 0
[求助] esphome代码报错求指点
发表于 2023-3-25 11:51:24 | 显示全部楼层 |阅读模式
用机器人写了一个esphome的代码,用于将接收到的MQTT字符串转化为十六进制然后用串口发送;不同的topic设置不同的帧头。 复制到esphome中提示报错,检查了好多遍也没有发现问题出在哪?特请教指点。
esphome:
  friendly_name: test11
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "******************"
ota:
  password: "********************"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Test11 Fallback Hotspot"
    password: "xsV4FctkoFsO"
mqtt:
  broker: "MQTT服务器地址"
  username: "MQTT用户名"
  password: "MQTT密码"
uart:
  tx_pin: TX
  baud_rate: 9600
globals:
  - id: topic_data
    type: string[]
  - platform: mqtt
    state_topic: "mqtt_to_hex/#"
    on_value:
      then:
        - lambda: |-
            std::string topic = id(state.get_topic());
            if (topic.length()13) {
              return;
            std::string data_str = state.get_value_string();
            int topic_id = std::stoi(topic.substr(11));
            float data = data_str.toFloat();
            int data_int = (int)(data * 10);
            // 将数据转化为十六进制字符串
            std::stringstream stream;
            stream::hex < data_int;
            std::string data_hex = stream.str();
            // 保证数据长度为2
            if (data_hex.length() == 1) {
              data_hex = "0" + data_hex;
            // 计算帧头和帧尾
            std::string header = "AA 55 " + data_hex.substr(0, 1) + std::to_string(topic_id) + " + data_hex.substr(1) + " ";
            int sum = 0;
            for (int i = 0; i < header.length(); i += 3) {
              sum += std::stoi(header.substr(i, 2), nullptr, 16);
            header += std::to_string(sum % 256) + " 55 AA";
            // 发送串口数据
            ESP_LOGD("mqtt_to_hex", "Sending data: %s", header.c_str());
            uart.write(reinterpret_cast<const uint8_t*>(header.c_str()), header.length());
      # 将订阅的topic保存到全局变量中,供lambda表达式使用
      - lambda: |-
          int i = 0;
          for (; i < 10; i++) {
            if (topic_data[i] == "") {
              topic_data[i] = id(state.get_topic());
              break;
          if (i == 10) {
            ESP_LOGW("mqtt_to_hex", "Too many topics to subscribe");
      # 取消订阅时将对应的topic从全局变量中删除
      - mqtt.publish:
          topic: "mqtt_to_hex/unsubscribe"
          payload: !lambda |-
            for (int i = 0; i < 10; i++) {
              if (topic_data[i] == topic) {
                topic_data[i] = "";
                break;
  # 订阅mqtt_to_hex/#以获取所有数据
  - platform: mqtt
    state_topic: "mqtt_to_hex/subscribe"
    icon: "mdi:arrow-down"
    on_value:
      then:
        - mqtt.subscribe:
automation:
  - trigger:
      platform: mqtt
      topic: mqtt_to_hex/unsubscribe
    action:
      - mqtt.publish:
          topic: "mqtt_to_hex/unsubscribed"
          payload: !lambda |-
            std::string topic = id(trigger.topic);
                topic_data[i] = "";
                break;
GMT+8, 2025-12-16 22:21 , Processed in 0.991461 second(s), 9 queries , MemCached On.
