查看: 3869|回复: 8
[求助] esp8266+ld2410人体传感器
发表于 2023-3-21 23:37:43 | 显示全部楼层 |阅读模式
OXOOG))1%M_7W`$X1V3J.png [U0[P22ESKMO`F12Z2@R{1D.png ZZXKBGV@GM1GH6XQJHXNZNE.png
esphome:
  friendly_name: ESPHome Web cb568c
esp8266:
  board: nodemcuv2
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "GX0rPi9teOIPEEE37M73xD6NNYIePyC4CMCd8F5EYXQ="
ota:
wifi:
  ssid: "???"
  password: "!!!!!!!!!!!"
  ap:
    ssid: "Esphome-Web-Cb568C"
    password: "12345678"
captive_portal:
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
  timeout: 61s
  max_move_distance : 6m
  max_still_distance: 0.75m
  g0_move_threshold: 50
  g0_still_threshold: 0
  g1_move_threshold: 50
  g1_still_threshold: 0
  g2_move_threshold: 40
  g2_still_threshold: 40
  g3_move_threshold: 30
  g3_still_threshold: 40
  g4_move_threshold: 20
  g4_still_threshold: 30
  g5_move_threshold: 15
  g5_still_threshold: 30
  g6_move_threshold: 15
  g6_still_threshold: 20
  g7_move_threshold: 15
  g7_still_threshold: 20
  g8_move_threshold: 15
  g8_still_threshold: 20
  - platform: ld2410
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
无法使用,显示未知状态
发表于 2023-3-22 09:18:50 | 显示全部楼层
是不是用的nodemcu,好像是供电的问题
发表于 2023-3-22 09:56:02 | 显示全部楼层
别把密码发出来呀
发表于 2023-3-22 12:54:54 | 显示全部楼层
首先检测tx_pin与rx_pin有没有按规范反接
 楼主| 发表于 2023-3-23 22:16:02 | 显示全部楼层
不是,单独供电
 楼主| 发表于 2023-3-23 22:18:43 | 显示全部楼层
正反都试过
发表于 2023-3-24 11:28:09 | 显示全部楼层
反正我用esp32也不省心,只要用这种方式接入,芯片就总是在有人状态显示无人,只接io输出口就没事,估计是bug吧
发表于 2025-11-15 11:20:13 | 显示全部楼层
看看信息
发表于 2025-11-15 11:21:24 | 显示全部楼层
学习学习
GMT+8, 2026-2-6 00:25 , Processed in 0.110414 second(s), 10 queries , MemCached On.
