楼主: louis_lee
[新奇玩法] 【立省100%】小米系可视门铃本地存储
发表于 2023-7-22 12:02:32 来自手机 | 显示全部楼层
感谢楼主,已经实现小米智能门铃3的本地存储。
但是直接推送视频到手机还有问题,把stream_address直接推到旧手机的ha,无法播放,需要做什么处理吗?
折中的办法: 有人按门铃,旧手机播放存储的视频,延时很明显,能直接推流过去的话应该会快一些吧
发表于 2023-9-10 22:24:29 | 显示全部楼层
全自动门锁pro 不知道可不可以这样搞
发表于 2023-10-9 22:07:50 | 显示全部楼层
arthurfsy 发表于 2023-4-20 11:44
有使用群晖的大佬吗?2个mount命令都显示permission denied,好奇怪。权限都是开好了的 ...
我也是permission denied,群辉的分享出来的nfs通过mount命令挂载到pve下安装的ha虚拟机。
发表于 2023-10-9 23:27:11 | 显示全部楼层
群辉分享nfs在其他ubuntu系统可以挂载成功,咋在haos里面利用
mount -t nfs4 192.168.125.107:/volume1/Universe/xiaomi_video /media/xiaomi_video
,提示permission denied呢?
太奇怪了
发表于 2023-10-10 10:18:09 | 显示全部楼层
请教,这个在N1架设的HASSIO,可以正常使用吗?
昨晚试着按楼主教程做,发现系统没有安装ffmpeg
想在armbian系统先安装ffmpeg,又提示
root@hassio:~# apt install ffmpeg
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
ffmpeg : Depends: libavcodec58 (= 7:4.3.6-0+deb11u1)
          Depends: libavdevice58 (= 7:4.3.6-0+deb11u1) but it is not going to be installed
          Depends: libavfilter7 (= 7:4.3.6-0+deb11u1)
          Depends: libavformat58 (= 7:4.3.6-0+deb11u1) but it is not going to be installed
          Depends: libavresample4 (= 7:4.3.6-0+deb11u1) but it is not going to be installed
          Depends: libavutil56 (= 7:4.3.6-0+deb11u1) but it is not going to be installed
          Depends: libpostproc55 (= 7:4.3.6-0+deb11u1) but it is not going to be installed
          Depends: libsdl2-2.0-0 (>= 2.0.12) but it is not going to be installed
          Depends: libswresample3 (= 7:4.3.6-0+deb11u1) but it is not going to be installed
          Depends: libswscale5 (= 7:4.3.6-0+deb11u1) but it is not going to be installed
homeassistant-supervised : Depends: systemd-resolved
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
发表于 2023-10-14 16:24:59 | 显示全部楼层
脚本代码配置好了,自动化里的 door_video_autosave 也有执行的动作
但是 /media/xiaomi_video 路径下没有生成任何文件,这是哪里有问题呢?
/media/xiaomi_video 路径权限有设置可写
发表于 2023-10-15 15:08:53 | 显示全部楼层
谢谢分享,mark
发表于 2023-10-19 10:43:54 | 显示全部楼层
感谢楼主,按照部署完后最后保存的视频比米家的视频长很多,例如米家只有几秒,但是存下来的视频有几十秒 ,视频中有很长的时间的画面是不动的,这种情况是什么原因?
发表于 2023-10-19 20:01:29 | 显示全部楼层
ltt1008 发表于 2023-3-31 01:53
感谢感谢。如果有遇到ffmpeg拼接音画不同步变速问题的,可以试试在35楼的ffmpeg -protocol这一行下添加,
我的情况是米家里面10多秒的视频,用这个方法保存下来会有1分多钟,保存下来的视频有很多时间画面是静止的,而且画面里的时间不会变,这种是你说的这种情况吗
发表于 2023-10-20 16:41:49 | 显示全部楼层
miaoer 发表于 2023-3-13 14:54
我的智能门铃也是这样,只播放第一段   用chrome的猫抓插件看了下,AES-128加密还有偏移,估计ffmpeg没法 ...
➜  /config ./xiaomi_video_autosave.sh
./xiaomi_video_autosave.sh: line 19: ffmpeg: command not found
你好 直接会报错啊 ffmpeg 要怎么安装啊
GMT+8, 2025-9-19 02:51 , Processed in 0.228815 second(s), 12 queries , MemCached On.
