查看: 8915|回复: 5
[求助] 博联 sp mini 插座无法接入hass.io
发表于 2017-12-7 21:06:33 | 显示全部楼层 |阅读模式
今天我装好了hass.io (ubuntu.16.04,vm虚拟机环境),也装好了homebridge,手机能显示网桥,但是在将我的博联sp mini   插座 ,接入ha和homebridge时,怎么也连不上?configuration.yaml配置文件如下:
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 30.5801
  longitude: 114.2734
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
group: !include groups.yaml
script: !include scripts.yaml
switch 1:
     - platform: broadlink
         host: 192.168.0.106
         mac: 'B4:43:0D:C4:F0:3D'
         timeout: 15
         type: sp2
         friendly_name: 'SP-MINI'
config.json配置文件如下:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://192.168.0.129:8123",
    "password": "",
    "supported_types": ["fan", "garage_door", "input_boolean", "light", "lock", "media_player", "rollershutter", "scene", "switch"]
我想接入ha和homebride,怎么弄都不行,请教各位大佬,在此拜谢!
发表于 2017-12-7 21:20:43 | 显示全部楼层
type: sp2 改成 type:  spmini2试试
 楼主| 发表于 2017-12-7 22:25:53 来自手机 | 显示全部楼层
好的,明早上班试试!
发表于 2017-12-8 01:25:00 | 显示全部楼层
2楼正解 spmini2 和miniplus我都连成功过。但是mini2要稳定一些,个人感觉
发表于 2017-12-17 09:32:13 | 显示全部楼层
楼主请问你参照哪个教程的 谢谢
 楼主| 发表于 2017-12-28 14:53:41 | 显示全部楼层
GMT+8, 2025-12-25 11:55 , Processed in 0.825890 second(s), 11 queries , MemCached On.
