查看: 2612|回复: 4
[求助] localtuya 是否可以自定义platform,太难了
发表于 2023-3-7 01:46:53 | 显示全部楼层 |阅读模式
目前localtuya升级到了最新版本,但是我发现我家的一个电动大门始终不行, 通过tuyalot 调试设备, 返回如下的dpid,
  "result": {
    "category": "qt",
    "functions": [
        "code": "wfh_open",
        "dp_id": 101,
        "type": "Boolean",
        "values": "{}"
        "code": "wfh_close",
        "dp_id": 102,
        "type": "Boolean",
        "values": "{}"
        "code": "wfh_stop",
        "dp_id": 103,
        "type": "Boolean",
        "values": "{}"
        "code": "wfh_lock",
        "dp_id": 104,
        "type": "Boolean",
        "values": "{}"
        "code": "fast_op",
        "dp_id": 110,
        "type": "Boolean",
        "values": "{}"
    "status": [
        "code": "wfh_open",
        "dp_id": 101,
        "type": "Boolean",
        "values": "{}"
        "dp_id": 102,
        "type": "Boolean",
        "values": "{}"
        "code": "wfh_stop",
        "dp_id": 103,
        "type": "Boolean",
        "values": "{}"
        "code": "wfh_lock",
        "dp_id": 104,
        "type": "Boolean",
        "values": "{}"
        "code": "return_state",
        "dp_id": 105,
        "type": "Integer",
        "values": "{\"unit\":\"\",\"min\":0,\"max\":128,\"scale\":1,\"step\":1}"
        "code": "l_close",
        "dp_id": 106,
        "type": "Boolean",
        "values": "{}"
        "code": "l_open",
        "dp_id": 107,
        "type": "Boolean",
        "values": "{}"
        "code": "inrf",
        "dp_id": 108,
        "type": "Boolean",
        "values": "{}"
        "code": "fsw",
        "dp_id": 109,
        "type": "Boolean",
        "values": "{}"
        "code": "fast_op",
        "dp_id": 110,
        "type": "Boolean",
        "values": "{}"
        "code": "hidden_state",
        "dp_id": 111,
        "type": "Boolean",
        "values": "{}"
        "code": "wfh_rssi",
        "dp_id": 112,
        "type": "Integer",
        "values": "{\"unit\":\"\",\"min\":-200,\"max\":50,\"scale\":0,\"step\":1}"
我再想目前是2个情况,
1.需要将这些 DPID配置进去,比如配置到下图这个位置,但是不知道那个是开 那个是关啊
2,现有的这些选择,应该都是对应这大佬们 写的py,我感觉是没有一个适合我这个情况的,是不是应该参考着写一个新的platform
这个问题困扰半个多月了,  lot平台上 用 json调试是可以的, 大佬们能不能解释下 这个原理,你说用dpid把 不知道怎么配, 你说用json字符串吧, 也没地方写request啊, 太难了 救救孩子吧
发表于 2023-3-8 09:02:36 | 显示全部楼层
图片看不到
发表于 2023-3-9 07:25:13 来自手机 | 显示全部楼层
用nodered中的本地涂鸦节点应该可以
 楼主| 发表于 2023-5-18 22:24:00 | 显示全部楼层
大哥, 你说的这个没看明白啥意思呢, 是用nodered 发请求吗?
发表于 2023-11-25 01:59:55 | 显示全部楼层
"dp_id": xxx,对应的就是localtuya里面的id
GMT+8, 2025-12-17 07:28 , Processed in 0.515794 second(s), 13 queries , MemCached On.
