查看: 9983|回复: 27
[已解决] nodemcu+LD2410B制作人体存在传感器(新版配置文件)
发表于 2023-3-4 13:50:54 | 显示全部楼层 |阅读模式
采用nodemcu+LD2410B,刷入ESPhome固件
配置文件如下
esphome:
esp8266:
  board: nodemcuv2
wifi:
  ssid: "H3"
  password: "31222.."
  manual_ip:
    static_ip: 192.168.0.131
    gateway: 192.168.0.1
    subnet: 255.255.255.0
  ap:
    ssid: "2410"
    password: "123456789"
captive_portal:
logger:
  baud_rate: 0
api:
ota:
uart:
  baud_rate: 256000
  tx_pin: GPIO1  # Replace with your TX pin
  rx_pin: GPIO3  # Replace with your RX pin
  parity: NONE
  stop_bits: 1
ld2410:
  # 配置传感器组件
  - platform: ld2410
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
number:
  - platform: ld2410
    timeout:
    light_threshold:
      name: light threshold
    max_move_distance_gate:
      name: max move distance gate
    max_still_distance_gate:
      name: max still distance gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
binary_sensor:
  # 配置二进制传感器组件
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
此配置文件直接刷如后,进HA集成esphome设备中修改距离参数!!!
发表于 2023-3-4 14:44:15 | 显示全部楼层
报错信息里不是写的很清楚了嘛,配置文件增加下面代码
logger:
  baud_rate: 0
jole 手机认证
发表于 2023-3-4 14:53:33 | 显示全部楼层
模块通电连上WIFI后再给LD2410通电试试。
发表于 2023-3-4 15:05:49 | 显示全部楼层
TX和RX接线反了
 楼主| 发表于 2023-3-4 17:29:55 | 显示全部楼层
感谢回复,已修改
 楼主| 发表于 2023-3-4 17:30:57 | 显示全部楼层
感谢回复,确实先通电再接才可以
 楼主| 发表于 2023-3-4 17:32:24 | 显示全部楼层
感谢回复,第一次弄这个,不知道RX与TX需要对接
发表于 2023-3-4 21:26:40 来自手机 | 显示全部楼层
加上mcu板子,是为了远距离使用吗?
 楼主| 发表于 2023-3-5 10:28:28 | 显示全部楼层
172859773 发表于 2023-3-4 21:26
加上mcu板子,是为了远距离使用吗?
不会打板、焊接,mcu直接引出5V为了方便
发表于 2023-3-8 15:41:33 | 显示全部楼层
好吧,趁着今天LD2410B特价,也买几块玩玩.
GMT+8, 2026-1-14 04:41 , Processed in 0.525201 second(s), 15 queries , MemCached On.
