查看: 3228|回复: 2
[技术探讨] 求助esphome大佬 接收的外红码什么通过mqtt发送到node-red呢
发表于 2023-3-2 18:05:39 | 显示全部楼层 |阅读模式
不知道是esphome跟新了 还是怎么了 今日编译一天接收的外红码什么通过mqtt发送 都接收不了 node-red和mqttx调试软件都收不到esphome的web有提示收到遥控器
贴上esphome配置
esphome:
  platform: ESP32
  board: esp32dev
substitutions:
  switch_name:  broadlink_1
logger:
#esp32_ble_tracker:
#bluetooth_proxy:
#api:
ota:
# Wifi signal
  - platform: wifi_signal
    update_interval: 60s
wifi:
  ssid: xxxxx
  #password: !secret wifi_password
  ap:
    ssid: "${switch_name}"
    password: "12345678"
captive_portal:
web_server:
  port: 80
mqtt:
  broker: 192.168.1.122
  port: 1883
  username: mqtt
  password: mqtt
  discovery: true
button: #重启
  - platform: restart
    # inverted: true
##########按红外接收模块#####################
remote_receiver:
  pin:
    number: GPIO23
    inverted: True
#    mode: INPUT_PULLUP
  dump: all
  on_nec:
    then:
    - mqtt.publish:
        topic: esphome32/senso/ir
        payload: !lambda |-
          char temp[20];
          sprintf(temp, "%d:%d", x.address, x.command);
          ESP_LOGI("main", "rcv nec: %s", temp);
          return temp;
  on_panasonic:
    then:
    - mqtt.publish:
        payload: !lambda |-
          char temp[20];
          ESP_LOGI("main", "rcv pan: %s", temp);
          return temp;
  on_sony:
    then:
    - mqtt.publish:
        payload: !lambda |-
          char temp[20];
          sprintf(temp, "%d:%d", x.data, x.nbits);
          ESP_LOGI("main", "rcv sony: %s", temp);
          return temp;
  on_jvc:
    then:
    - mqtt.publish:
        payload: !lambda |-
          char temp[20];
          sprintf(temp, "%d", x.data);
          ESP_LOGI("main", "rcv jvc: %s", temp);
          return temp;
  on_rc5:
    then:
    - mqtt.publish:
        payload: !lambda |-
          char temp[20];
          ESP_LOGI("main", "rcv rc5: %s", temp);
          return temp;
3万
发表于 2023-3-2 19:24:22 | 显示全部楼层
esphome中显示这个信号格式不属于代码中所列的任何一种,就没有到publish那一步了。
也就是信号协议不支持,换个设备的红外码试试。
 楼主| 发表于 2023-3-2 20:43:40 | 显示全部楼层
也就是信号协议不支持 ...
大哥 我那个信号格式可以写吗 到发送到mqtt吗
GMT+8, 2025-12-31 17:04 , Processed in 1.285415 second(s), 11 queries , MemCached On.
