查看: 11777|回复: 5
让homebridge开机就启动2种方法都不行请指点?
发表于 2017-12-6 22:59:30 | 显示全部楼层 |阅读模式
方法1:
####将homebridge设置成随系统启动######
cd /
sudo useradd --system homebridge
sudo mkdir /var/homebridge
sudo cp ~/.homebridge/config.json /var/homebridge/
sudo cp -r ~/.homebridge/persist /var/homebridge
sudo chmod -R 0777 /var/homebridge
cd /etc/default
sudo nano homebridge
#########将下面的内容复制粘贴进去,然后Ctrl+X,然后Y,回车,保存退出####
# Defaults / Configuration options for homebridge
# The following settings tells homebridge where to find the config.json file and where to persist the data (i.e. pairing and others)
HOMEBRIDGE_OPTS=-U /var/homebridge
# If you uncomment the following line, homebridge will log more
# You can display this via systemd's journalctl: journalctl -f -u homebridge
# DEBUG=*
####分界线#####################################
cd /etc/systemd/system
sudo nano homebridge.service
[Unit]
Description=Node.js HomeKit Server
After=syslog.target network-online.target
[Service]
Type=simple
User=homebridge
EnvironmentFile=/etc/default/homebridge
ExecStart=/usr/lib/node_modules/homebridge/bin/homebridge $HOMEBRIDGE_OPTS
Restart=on-failure
RestartSec=10
KillMode=process
[Install]
WantedBy=multi-user.target
cd /
sudo systemctl daemon-reload
sudo systemctl enable homebridge
sudo systemctl start homebridge
sudo systemctl status homebridge
sudo reboot      ####重启树莓派####
###最后,你想返回去修改PIN码,MAC地址等等参数,可以按以下命令行来做####
sudo systemctl stop homebridge         ###停止homebridge运行###
cd /var/homebridge                     ###进入目录###
sudo nano config.json                  ###编辑配置文件###
sudo reboot                            ###重启树莓派####
方法二:   http://blog.csdn.net/conghua19/article/details/77934391
以上2个方法都试过了,开机后手机仍然无法连接homekit,
现在homebridge在命令提示符下直接输入homebridge启动是可以
发表于 2017-12-7 11:34:03 | 显示全部楼层
sudo systemctl status homebridge  用这个命令看一下 状态是不是启动了。。
发表于 2017-12-7 14:52:25 | 显示全部楼层
HASS.IO适合你
发表于 2017-12-9 10:02:51 | 显示全部楼层
用“which homebridge”命令看一下你的homebridge安装在哪里了,是不是和“ExecStart=/usr/lib/node_modules/homebridge/bin/homebridge $HOMEBRIDGE_OPTS”里面所表述的目录一致
jh8
发表于 2018-5-3 17:59:57 | 显示全部楼层
同求啊, 方法一经常不正常运行,设备还经常少掉
发表于 2018-5-14 11:05:29 | 显示全部楼层
分享一下我的方法:
1.安装forever
sudo npm install -g forever  作用是在homebridge挂掉后会自动重启homebridge
2.编写脚本startHombridge,放在/home/pi下
forever start -l homebridge.`date +%Y-%m-%d#%H:%M:%S`.log /usr/local/bin/homebridge
3.在 /etc/rc.local 中添加
su pi -c "exec /home/pi/startHombridge"'
这样开机时以pi用户执行脚本,使用forever启动homebridge
GMT+8, 2026-1-3 10:58 , Processed in 0.175245 second(s), 13 queries , MemCached On.
