查看: 3174|回复: 1
[技术探讨] HA加载项启动时提示无法验证该怎么处理?
发表于 2023-2-24 23:49:04 | 显示全部楼层 |阅读模式
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:124
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 23:16:45 (3 occurrences)
Last logged: 23:39:45
Failed to to call /addons/core_samba/options/validate -
Failed to to call /addons/core_mosquitto/options/validate -
Logger: homeassistant.components.hassio.handler
Source: components/hassio/handler.py:476
Timeout on /addons/core_samba/options/validate request
Timeout on /addons/core_mosquitto/options/validate request
Logger: homeassistant.components.esphome.dashboard
Source: helpers/update_coordinator.py:215
Integration: ESPHome (documentation, issues)
First occurred: 22:40:29 (1 occurrences)
Last logged: 22:40:29
Error requesting ESPHome Dashboard data: Cannot connect to host 127.0.0.1:62695 ssl:default [Connect call failed ('127.0.0.1', 62695)]
之前安装HA都能正常启动及更改配置,之后重新安装之后就遇到这个两个问题
无法启动,启动后都提示无法验证,或者在配置时提示未知错误,附上报错日志
各位大佬,有遇到一样问题的吗,该怎么处理
 楼主| 发表于 2023-2-26 18:29:10 | 显示全部楼层
有大佬知道怎么处理吗
GMT+8, 2026-1-17 15:26 , Processed in 0.721416 second(s), 11 queries , MemCached On.
