查看: 10190|回复: 5
[技术探讨] homebridge加载小米网关2代出错,恳请大神指教
发表于 2017-12-6 19:59:07 | 显示全部楼层 |阅读模式
设备:群晖、小米网关、Yeelight灯泡(已开启局域网控制),启动后意外终止。错误信息和配置文件如下,请大神帮忙看看问题出在哪?
config.json
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:56",
        "port": 56688,
        "pin": "666-55-999"
    "platforms": [
            "platform": "AqaraPlatform",
            "sid": [
                "7831DCA37FBE"
            "password": [
                "no3z3xi60572c3cx"
            "platform": "yeelight",
            "name": "Yeelight"
    "accessories": [
            "accessory": "Synology",
            "name": "Synology_NAS",
            "ip": "192.168.1.55",
            "mac": "00:11:35:70:6F:68",
            "port": "5000",
            "secure": false,
            "account": "ptlzx",
            "password": "1234567890",
            "version": 6
install.sh
#!/bin/bash
apt-get install libavahi-compat-libdnssd-dev
npm install -g homebridge-aqara
npm install -g homebridge-yeelight
npm install -g homebridge-synology
错误日志:
{"id":-1,"method":"get_prop","params":["power"]}
/usr/local/lib/node_modules/homebridge-aqara/lib/AqaraAccessoryFactory.js:75
    var gatewaySid = this.gatewaySids[accessory.UUID];
TypeError: Cannot read property 'UUID' of undefined
    at AqaraAccessoryFactory.autoRemoveAccessory (/usr/local/lib/node_modules/homebridge-aqara/lib/AqaraAccessoryFactory.js:75:48)
    at Timeout._onTimeout (/usr/local/lib/node_modules/homebridge-aqara/lib/AqaraPlatform.js:103:15)
    at ontimeout (timers.js:469:11)
    at tryOnTimeout (timers.js:304:5)
    at Timer.listOnTimeout (timers.js:264:5)
论坛风云人物
发表于 2017-12-6 23:51:55 | 显示全部楼层
请使用 homebridge-mi-aqara ,homebridge-aqara已经半年没更新了= =
 楼主| 发表于 2017-12-7 07:38:20 | 显示全部楼层
出错了,"platform": "AqaraPlatform"怎么改?麻烦再给指点下,谢谢!
错误信息:
      throw new Error("The requested platform '" + name + "' was not registered by any plugin.");
Error: The requested platform 'AqaraPlatform' was not registered by any plugin.
    at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:122:13)
    at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:284:45)
    at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:80:36)
    at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:573:30)
    at Object.Module._extensions..js (module.js:584:10)
    at Module.load (module.js:507:32)
    at tryModuleLoad (module.js:470:12)
    at Function.Module._load (module.js:462:3)
论坛风云人物
发表于 2017-12-7 17:07:55 | 显示全部楼层
卸载掉 homebridge-aqara 然后安装 homebridge-mi-aqara,把 aqaraplatform 这一段配置都删掉,然后用 mi-aqara 的配置。
 楼主| 发表于 2017-12-7 22:35:32 | 显示全部楼层
cxlwill 发表于 2017-12-7 17:07
卸载掉 homebridge-aqara 然后安装 homebridge-mi-aqara,把 aqaraplatform 这一段配置都删掉,然后用 mi-aq ...
按你的指导改了错误没有了,iPhone家庭APP里yeelight灯、homebridge、群晖nas都正常显示并使用,但是奇怪的是里面并没有小米网关2这项,是不是因为我没有zigbee子设备的缘故,所有家庭APP不会显示小米网关这项。还是说小米网关还是没有配置好。
 楼主| 发表于 2017-12-7 22:36:44 | 显示全部楼层
GMT+8, 2025-12-11 08:42 , Processed in 0.757842 second(s), 8 queries , MemCached On.
