查看: 9431|回复: 12
[硬件DIY] 把德力西DDSU6606ctr电表通过无线485模块接入HA
发表于 2023-2-22 22:06:57 | 显示全部楼层 |阅读模式
PCB来自 liwei19920307 的项目 ESP485 ,GitHub地址:https://github.com/liwei19920307/ESP485/ 原作者使用正泰DDSU666电表,本人家中都是使用德力西的空开,因此想改用德力西的电表进行接入
ESPHOME代码
substitutions:
  device_name: esp485
esphome:
  # platformio_options:
  #   board_build.flash_mode: dio
  #   board_build.mcu: esp32c3
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
logger:
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  fast_connect: on
web_server:
  port: 80
button:
  - platform: restart
time:
  - platform: sntp
uart:
  rx_pin: 18
  tx_pin: 19
  baud_rate: 2400
  data_bits: 8
  stop_bits: 1
  parity: EVEN
modbus:
  send_wait_time: 200ms
modbus_controller:
  - id: ${device_name}_modbus_controller
    modbus_id: ${device_name}_modbus
    address: 0x01
    command_throttle: 200ms
    setup_priority: -10
    update_interval: 10s
text_sensor:
  - platform: wifi_info
    ip_address:
    mac_address:
  - platform: uptime
  - platform: wifi_signal
    update_interval: 60s
 #当前电压
  - platform: modbus_controller
    modbus_controller_id: ${device_name}_modbus_controller
    address: 0x0300
    register_count: 1
    unit_of_measurement: V
    register_type: holding
    value_type: U_WORD
    accuracy_decimals: 1
    device_class: voltage
    filters:
    - multiply: 0.1
 #当前电流
    address: 0x0303
    register_count: 1
    unit_of_measurement: A
    value_type: U_WORD
    accuracy_decimals: 2
    device_class: current
    filters:
      - multiply: 0.01
#瞬时A相有功功率
    address: 0x0306
    register_count: 1
    unit_of_measurement: kW
    value_type: U_WORD
    filters:
      - multiply: 0.01
    device_class: power
    address: 0x000A
    register_count: 2
    unit_of_measurement: kWh
    value_type: S_DWORD
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
参与人数 6金钱 +66 HASS币 +10 收起 理由
sorrypqa + 16 高手,这是高手!
+ 20 + 10 感谢楼主分享!
yhlove + 5 感谢楼主分享!
gx19970920 + 8
huahua + 5 感谢楼主分享!
jjcs + 12 高手,这是高手!
发表于 2023-2-23 09:47:42 | 显示全部楼层
我家的电量统计就是按照原作者的方案弄的,很准,全天的基本误差0.几度,无影响
Ari 手机认证
发表于 2023-2-23 09:47:50 | 显示全部楼层
只有三个传感器信息吗?
 楼主| 发表于 2023-2-23 13:11:05 | 显示全部楼层
Ari 发表于 2023-2-23 09:47
只有三个传感器信息吗?
暂时测试了三个
发表于 2023-2-25 09:31:40 | 显示全部楼层
电表多少钱
 楼主| 发表于 2023-2-25 09:33:30 | 显示全部楼层
京东90左右
发表于 2023-2-25 09:36:13 | 显示全部楼层
正泰60左右,我记得
 楼主| 发表于 2023-2-25 11:59:52 | 显示全部楼层
yiwlg 发表于 2023-2-25 09:36
正泰60左右,我记得
正泰DDSU666 120
发表于 2023-2-27 08:52:44 | 显示全部楼层
大佬 问一下问题可以吗  esp32可以做485 tcp透传模式吗  让node-red发modbus协议 查询数据或者控制设备继电器什么的
 楼主| 发表于 2023-2-27 13:35:06 | 显示全部楼层
gmshiwoge 发表于 2023-2-27 08:52
大佬 问一下问题可以吗  esp32可以做485 tcp透传模式吗  让node-red发modbus协议 查询数据或者控制设备继电 ...
那用esp32接ttl转rs485模块就好了
GMT+8, 2026-1-16 04:51 , Processed in 0.381498 second(s), 7 queries , MemCached On.
