查看: 4258|回复: 3
homebridge可以运行,但还是报错,而且无法自动发现broadlink rm pro
发表于 2017-12-5 20:47:38 | 显示全部楼层 |阅读模式
pi@raspberrypi:~ $ homebridge
*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <[url=http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>]http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>[/url]
*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <[url=http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs&f=DNSServiceRegister>]http://0pointer.de/avahi-compat? ... ServiceRegister>[/url]
[12/5/2017, 12:40:29 PM] Loaded plugin: homebridge-broadlink-rm
[12/5/2017, 12:40:29 PM] Registering platform 'homebridge-broadlink-rm.BroadlinkRM'
[12/5/2017, 12:40:29 PM] ---
[12/5/2017, 12:40:29 PM] Loaded config.json with 0 accessories and 1 platforms.
[12/5/2017, 12:40:29 PM] Loading 1 platforms...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing BroadlinkRM platform...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Air Conditioner Advanced Linking autoSwitch "A/C Auto Switch"
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Learn'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Scan Frequency'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Auto-off Switch'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'TV On/Off'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Channel Up'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Channel Down'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Volume Up'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Volume Down'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Entertainment'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Entertainment 2'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Light'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Air Conditioner'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Air Conditioner Advanced'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'A/C Auto Switch'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Fan'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Garage Door'...
[12/5/2017, 12:40:29 PM] [Broadlink RM] Initializing platform accessory 'Blind'...
[12/5/2017, 12:40:29 PM] Loading 0 accessories...
Setup Payload:
X-HM://0023ISYX0ENGM
Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
    │ 031-45-156 │
[12/5/2017, 12:40:29 PM] Homebridge is running on port 51826.
[12/5/2017, 12:40:31 PM] [Broadlink RM] Air Conditioner setCurrentHeatingCoolingState: 0
[12/5/2017, 12:40:31 PM] [Broadlink RM] Air Conditioner setCurrentHeatingCoolingState: already 0
[12/5/2017, 12:40:31 PM] [Broadlink RM] Air Conditioner setTargetHeatingCoolingState: 0
[12/5/2017, 12:40:31 PM] [Broadlink RM] Air Conditioner setTargetHeatingCoolingState: already 0
[12/5/2017, 12:40:31 PM] [Broadlink RM] Air Conditioner Advanced setCurrentHeatingCoolingState: 0
[12/5/2017, 12:40:31 PM] [Broadlink RM] Air Conditioner Advanced setCurrentHeatingCoolingState: already 0
[12/5/2017, 12:40:31 PM] [Broadlink RM] Air Conditioner Advanced setTargetHeatingCoolingState: 0
[12/5/2017, 12:40:31 PM] [Broadlink RM] Air Conditioner Advanced setTargetHeatingCoolingState: already 0
[12/5/2017, 12:40:31 PM] [Broadlink RM] Garage Door setCurrentDoorState: 1
[12/5/2017, 12:40:31 PM] [Broadlink RM] Garage Door setCurrentDoorState: already 1
[12/5/2017, 12:40:31 PM] [Broadlink RM] Garage Door setTargetDoorState: 1
[12/5/2017, 12:40:31 PM] [Broadlink RM] Garage Door setTargetDoorState: already 1
^C[12/5/2017, 12:45:41 PM] Got SIGINT, shutting down Homebridge...
pi@raspberrypi:~ $
 楼主| 发表于 2017-12-5 21:25:04 | 显示全部楼层
我把rm pro设备按reset键设置成蓝灯快闪模式,homebridge也仍然发现不良它?难道是我的rm pro设备太老了吗?买了大概有2年时间了!!!
发表于 2017-12-9 21:39:59 | 显示全部楼层
你的rm pro有接入你的wifi网络吗?
你需要把rm pro设备按reset键设置成蓝灯快闪模式,用原厂apps先接入wifi,那个homebridge才可以找到的。
 楼主| 发表于 2017-12-10 11:04:07 | 显示全部楼层
你需要把rm pro设备按reset键设置成蓝灯快闪模式,用原厂apps先接入wif ...
已经搞定了,谢谢
GMT+8, 2025-8-10 23:06 , Processed in 0.048798 second(s), 7 queries , MemCached On.
