查看: 7736|回复: 5
为什么没有一个人把sd卡直接img
发表于 2017-12-5 16:07:40 | 显示全部楼层 |阅读模式
为什么没有一个人是把做好homekit系统后,直接把sd卡里的所有数据直接做个img镜像文件,别人下载镜像文件写入sd卡,一切配置都可以了,所有的安装插件都省了呢?
我现在按这2位的教程都没搞成,
https://bbs.hassbian.com/thread-441-1-1.html
https://bbs.hassbian.com/thread-473-1-1.html
发表于 2017-12-5 16:13:41 | 显示全部楼层
是啊,对于某些人来说,确实有需要。
 楼主| 发表于 2017-12-5 16:50:07 | 显示全部楼层
安装失败
sudo npm install -g --unsafe-perm homebridge
pi@raspberrypi:~ $ sudo npm install -g --unsafe-perm homebridge
/usr/bin/homebridge -> /usr/lib/node_modules/homebridge/bin/homebridge
> [url=mailto:[email protected]][email protected][/url] install /usr/lib/node_modules/homebridge/node_modules/mdns
> node-gyp rebuild
make: Entering directory '/usr/lib/node_modules/homebridge/node_modules/mdns/build'
  CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
In file included from ../src/dns_sd.cpp:1:0:
../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
#include <dns_sd.h>
compilation terminated.
dns_sd_bindings.target.mk:149: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
make: Leaving directory '/usr/lib/node_modules/homebridge/node_modules/mdns/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
gyp ERR! stack     at emitTwo (events.js:106:13)
gyp ERR! stack     at ChildProcess.emit (events.js:194:7)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
gyp ERR! System Linux 4.9.59-v7+
gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/lib/node_modules/homebridge/node_modules/mdns
gyp ERR! node -v v7.10.1
gyp ERR! node-gyp -v v3.5.0
gyp ERR! not ok
/usr/lib
└── (empty)
npm ERR! Linux 4.9.59-v7+
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "--unsafe-perm" "homebridge"
npm ERR! node v7.10.1
npm ERR! npm  v4.2.0
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [url=mailto:[email protected]][email protected][/url] install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [url=mailto:[email protected]][email protected][/url] install script 'node-gyp rebuild'.
npm ERR! Make sure you have the latest version of node.js and npm installed.
npm ERR! If you do, this is most likely a problem with the mdns package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR!     node-gyp rebuild
npm ERR! You can get information on how to open an issue for this project with:
npm ERR!     npm bugs mdns
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls mdns
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR!     /root/.npm/_logs/2017-12-05T08_48_09_600Z-debug.log
pi@raspberrypi:~ $
 楼主| 发表于 2017-12-5 16:54:17 | 显示全部楼层
安装失败,安装不带--unsafe-perm后缀参数的也不行
sudo npm install -g  homebridge
pi@raspberrypi:~ $ sudo npm install -g homebridge
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/7.10.1"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/lib/node_modules/homebridge/node_modules/mdns/.node-gyp"
 #include <dns_sd.h>
gyp ERR! not ok
/usr/lib
└── (empty)
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "homebridge"
npm ERR! npm  v4.2.0
npm ERR! errno 1
npm ERR!
npm ERR!     /root/.npm/_logs/2017-12-05T08_53_15_067Z-debug.log
pi@raspberrypi:~ $
发表于 2017-12-9 14:23:21 | 显示全部楼层
好主意,回头我来上传一个纯净版的。。。
noel
发表于 2017-12-14 20:27:32 | 显示全部楼层
善用搜索,有sd卡备份的,
比如:https://bbs.hassbian.com/thread-1786-1-1.html
GMT+8, 2025-12-17 17:28 , Processed in 0.061359 second(s), 14 queries , MemCached On.
