查看: 4047|回复: 5
[技术探讨] 代码可以改为是or条件吗?
发表于 2023-2-12 04:04:09 | 显示全部楼层 |阅读模式
这是判断状态显示图标,但是需要3个开关都是on状态,能否改为是or,就是3个开关其中一个on就显示,而不是必须3个同时判断。
type: conditional
conditions:
  - entity: switch.lumi_n3acn3_a235_left_switch_service
    state: 'on'
  - entity: switch.lumi_n3acn3_a235_right_switch_service
    state: 'on'
  - entity: switch.lumi_n3acn3_a235_middle_switch_service
    state: 'on'
card:
  show_name: true
  show_icon: true
  type: button
  tap_action:
    action: toggle
  entity: script.1675790238354
  icon: mdi:book-open-blank-variant
  show_state: true
发表于 2023-2-12 07:10:13 | 显示全部楼层
可以,文档在这里 https://www.home-assistant.io/do ... tions/#or-condition
还可以像这样把 and 和 or 混着
#    condition:
#      - condition: or
#        conditions:
#          - condition: and
#            conditions:
#              - entity_id: binary_sensor.master_toilet_basin_motion_sensor_motion
#                condition: state
#                state: "on"
#              - entity_id: sensor.master_toilet_basin_motion_sensor_light
#                condition: numeric_state
#                below: "150"
#          - condition: and
#            conditions:
#              - entity_id: binary_sensor.master_toilet_shower_motion_sensor_motion
#                condition: state
#                state: "on"
#              - entity_id: sensor.master_toilet_shower_motion_sensor_light
#                below: "10"
hyq
发表于 2023-2-12 09:10:29 | 显示全部楼层
- or:
       - "{{ is_state('switch.zhu_wo_deng_switch_1','on') }}"
       - "{{ is_state('switch.zhu_wo_deng_switch_1_2','on') }}"
       - "{{ is_state('switch.zhu_wo_deng_switch_2','on') }}"
       - and:
                  {{ states('sensor.liang_du_chuan_gan_qi_luminosity')|int <
                   10 }}
              - "{{  now() > today_at(\"18:00\") or now() < today_at(\"7:00\") }}"
         - and:
               - "{{ is_state('binary_sensor.ren_ti_chuan_gan_qi_2','off') }}"
               - "{{ is_state('weather.he_s',['sunny','partlycloudy']) }}"
                    {{ states('sensor.liang_du_chuan_gan_qi_luminosity')|int >
                    800 }}
                - "{{ state_attr('weather.he_s','temperature')|int > 36 }}"
 楼主| 发表于 2023-2-12 15:22:39 | 显示全部楼层
还可以像这样把 and 和 or  ...
我按你给的代码出错,然后按文档的也出错。。请问我上面的代码,如何改才对?能按我的改看参考吗?
发表于 2023-2-12 22:46:44 | 显示全部楼层
gdxinge 发表于 2023-2-12 15:22
我按你给的代码出错,然后按文档的也出错。。请问我上面的代码,如何改才对?能按我的改看参考吗? ...
你好像在自创语法啊。。所有非template的condition都需要condition关键字,而且你还混用了template,and和or ,个人建议在把最基础的语法学明白之前不要用template(即一开始不要用任何 is_state, state_attr)。
我给你举个例子
你写的
- or:
应该改成
      - condition: or
        conditions:
          - entity_id: switch.zhu_wo_deng_switch_1
            condition: state
            state: "on"
          - entity_id: switch.zhu_wo_deng_switch_1_2
            condition: state
            state: "on"
          - entity_id: switch.zhu_wo_deng_switch_2
            condition: state
            state: "on"
这些都有代替的,上面就是代替is_state的,要判断state_attr可以用类似的来判断
condition:
  entity_id: climate.living_room_thermostat
  attribute: temperature
  above: 17
  below: 25
这个也好debug一些。把这个学清楚了,还有yaml的语法,建议再去学template,template的debug会更麻烦一些。
官方文档里有更多的例子。 我的HA自动化里也有很多例子,你有兴趣也可以看看https://github.com/relliky/Tais_ ... ree/master/packages
----------------------------EDIT--------------------
纠正一下,刚刚开官方文档发现好早就支持缩写的or和and了,是我孤陋寡闻了
发表于 2023-6-7 22:03:48 | 显示全部楼层
你好,最后问题解决了吗?想问下怎么实现的?
GMT+8, 2026-1-17 02:49 , Processed in 0.169807 second(s), 7 queries , MemCached On.
