查看: 2749|回复: 1
[求助] 关于获取传感器属性值的问题求教大神
发表于 2023-2-7 15:59:40 | 显示全部楼层 |阅读模式
自己用的hacs安装了china southern power grid statistics获取南网电费
这个集成获取的上月电费数据属性如下格式:
state_class: total
last_month_by_day:
  - date: '2023-01-01'
    kwh: 15.63
  - date: '2023-01-02'
    kwh: 17.61
  - date: '2023-01-03'
    kwh: 21.64
  - date: '2023-01-04'
    kwh: 17.93
  - date: '2023-01-05'
    kwh: 17.1
  - date: '2023-01-06'
    kwh: 17.82
  - date: '2023-01-07'
    kwh: 20.11
  - date: '2023-01-08'
    kwh: 19.13
  - date: '2023-01-09'
    kwh: 17.93
  - date: '2023-01-10'
    kwh: 25.16
  - date: '2023-01-11'
    kwh: 17.56
  - date: '2023-01-12'
    kwh: 16.91
  - date: '2023-01-13'
    kwh: 22.52
  - date: '2023-01-14'
    kwh: 33.11
  - date: '2023-01-15'
    kwh: 24.08
  - date: '2023-01-16'
    kwh: 22.72
  - date: '2023-01-17'
    kwh: 19.13
  - date: '2023-01-18'
    kwh: 22.55
  - date: '2023-01-19'
    kwh: 21.61
  - date: '2023-01-20'
    kwh: 21.08
  - date: '2023-01-21'
    kwh: 23.1
  - date: '2023-01-22'
    kwh: 22.73
  - date: '2023-01-23'
    kwh: 21.58
  - date: '2023-01-24'
    kwh: 21.38
  - date: '2023-01-25'
    kwh: 18.29
  - date: '2023-01-26'
    kwh: 19.9
  - date: '2023-01-27'
    kwh: 20.92
  - date: '2023-01-28'
    kwh: 22.07
  - date: '2023-01-29'
    kwh: 21.88
  - date: '2023-01-30'
    kwh: 21.01
  - date: '2023-01-31'
    kwh: 22.98
unit_of_measurement: kWh
device_class: energy
icon: mdi:lightning-bolt
friendly_name: 上月用电量
求教大神怎么提取属性last_month_by_day里datekwh的值想做成图表卡片的形式显示出来。
想过用Apexcharts-card显示本月每天的电费使用情况
参考了帖子https://bbs.hassbian.com/forum.p ... =%E7%94%B5%E8%B4%B9
想使用这部分代码显示:
type: vertical-stack
cards:
  - type: custom:apexcharts-card
    header:
      show: true
      title: 当月用电趋势图
    graph_span: 35d
    span:
      start: month
      offset: '-30d'
    series:
      - entity: sensor.everyday_power2
        data_generator: |
          return entity.attributes.date.map((item, index) => {
           return [new Date(item).getTime(), entity.attributes.power[index]];
        extend_to: false
        float_precision: 2
实在不懂JS,data_generator部分怎么改都出不来数据,请求大神指点迷津
发表于 2023-2-9 16:05:29 | 显示全部楼层
检查下entity.attributes.date的数据类型是不是Array
GMT+8, 2025-12-17 07:22 , Processed in 0.978397 second(s), 7 queries , MemCached On.
