查看: 2473|回复: 5
[求助] HA今天更新最新版本群晖报错求助
发表于 2023-2-3 17:21:28 | 显示全部楼层 |阅读模式
主机更新到Home Assistant 2023.2.1Supervisor 2023.01.1Operating System 9.5前端版本: 20230202.0 - latest
群晖出现报错。求助。
日志如下:
Logger: homeassistant.config_entries
Source: components/synology_dsm/common.py:94
First occurred: 17:16:28 (1 occurrences)
Last logged: 17:16:28
Error setting up entry 10.10.100.50 for synology_dsm
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 68, in async_setup_entry
    await api.async_setup()
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/common.py", line 94, in async_setup
    await self.dsm.surveillance_station.update()
  File "/usr/local/lib/python3.10/site-packages/synology_dsm/api/surveillance_station/__init__.py", line 25, in update
    raw_data = await self._dsm.get(self.CAMERA_API_KEY, "List", max_version=7)
  File "/usr/local/lib/python3.10/site-packages/synology_dsm/synology_dsm.py", line 207, in get
    return await self._request("GET", api, method, params, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/synology_dsm/synology_dsm.py", line 282, in _request
    response = await self._execute_request(request_method, url, params, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/synology_dsm/synology_dsm.py", line 308, in _execute_request
    response = await self._session.get(url, params=params, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 919, in get
    self._request(hdrs.METH_GET, url, allow_redirects=allow_redirects, **kwargs)
TypeError: ClientSession._request() got an unexpected keyword argument 'max_version'
发表于 2023-2-3 17:37:22 来自手机 | 显示全部楼层
我的也报错了,一模一样的。
也许等2023.2.2 就会修复
 楼主| 发表于 2023-2-3 17:39:56 | 显示全部楼层
lhpsq 发表于 2023-2-3 17:37
我的也报错了,一模一样的。
群晖报错第一次出现貌似
发表于 2023-2-3 17:58:18 来自手机 | 显示全部楼层
我监控画面都是从群晖里过来的,现在都连不上了
发表于 2023-2-3 18:01:02 | 显示全部楼层
推荐以后升级只升级月末版本。。。
而且我还有很多hacs插件,一般修一下都得修几个小时。
发表于 2023-2-3 23:40:12 来自手机 | 显示全部楼层
你装到群晖哪里了 docker还是vmm
GMT+8, 2025-12-17 09:11 , Processed in 1.146459 second(s), 8 queries , MemCached On.
