查看: 3285|回复: 1
[插件集成] 2023.3之后自定义集成 async_setup_platforms 需要修改了
3万
发表于 2023-2-2 22:46:29 | 显示全部楼层 |阅读模式
Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for ha_cloud_music using this method at custom_components/ha_cloud_music/__init__.py, line 23: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for hf_weather using this method at custom_components/hf_weather/__init__.py, line 11: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for espplayer using this method at custom_components/espplayer/__init__.py, line 28: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for dlna_dmr_xiaodu using this method at custom_components/dlna_dmr_xiaodu/__init__.py, line 20: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
按提示找到以下代码:
修改为:
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
如果集成作者已更新,更新成新版本就好了。
发表于 2023-2-3 11:11:40 | 显示全部楼层
兼容性跟开玩笑一样
GMT+8, 2026-1-17 17:46 , Processed in 0.488104 second(s), 9 queries , MemCached On.
