查看: 2559|回复: 2
[求助] 小燕TERNCY-CM01窗帘电机接入zigbee2mqtt 付费
发表于 2023-1-30 04:31:15 | 显示全部楼层 |阅读模式
目前z2m只支持小燕的几个设备。我有一个TERNCY-CM01窗帘电机。目前能够接入zigbee2mqtt里,但是不能获取状态和控制。数据库条目如下
{"id":16,"type":"Router","ieeeAddr":"0xe0798dfffe815396","nwkAddr":17231,"manufId":4648,"manufName":"小燕","powerSource":"Unknown" ,"modelId":"TERNCY-CM01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":514,"inClusterList" :[0,3,4,5,258,64716],"outClusterList":[3,25],"clusters":{"genBasic":{"attributes":{"hwVersion":4,"modelId":"TERNCY -CM01","manufacturerName":"Xiaoyan","powerSource":0,"zclVersion":8}},"genOta":{"attributes":{"currentFileVersion":23}},"manuSpecificClusterAduroSmart":{"attributes":{"20":0}}},"binds":[],"configuredReportings":[],"meta":{}}},"hwVersion":4,"zclVersion":8,"interviewCompleted ":true,"meta":{},"lastSeen":1673633218570,"defaultSendRequestWhen":"immediate"}
转换文件如下
    zigbeeModel: ['TERNCY-CM01'],
    model: 'TERNCY-CM01',
    vendor: 'Xiaoyan',
    description: '小燕开合帘电机',
    fromZigbee: [],
    toZigbee: [],
        exposes: [e.linkquality(), e.battery()],
我应该如何写转换文件才能控制呢。恳请大神支招。如果很麻烦也愿意付费。
另外不知道有没有大神能帮我解读指导一下怎么理解这些变量常量的意思呢。以便于举一反三。谢谢
发表于 2024-10-3 22:24:12 | 显示全部楼层
同问。怎么没人回复
发表于 2024-10-4 20:17:21 | 显示全部楼层
这件事按道理是好办的
只是我手头没有这个设备,也就无法调试,这玩意要调试才能知道,毕竟他们没有文档..
除非你找到对应有这个设备的人,并且也接入了zigbee2mqtt,不然恐怕只能自己学一手代码了
之前小燕的Home Assistant 插件也有些设备不能支持,我调试了半天改了下插件才支持
GMT+8, 2025-12-17 16:56 , Processed in 0.970328 second(s), 13 queries , MemCached On.
