查看: 2695|回复: 3
[求助] esphome升级版本后舵机不工作了
发表于 2023-1-23 02:17:17 | 显示全部楼层 |阅读模式
我用esp32和mg90通过esphome实现开关控制,但是今天更新完以后我的代码失效了,舵机不动了,代码如下:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key:
ota:
  password:
wifi:
  ssid:
  password:
  fast_connect: true
  ap:
    ssid: "Test Fallback Hotspot"
    password:
captive_portal:
switch:
  - platform: gpio
    pin: GPIO27
    on_turn_off:
      - servo.write:
          level: -14%
      - delay: 0.1s
      - servo.write:
          level: 4%
    on_turn_on:
      - servo.write:
          level: +22%
      - delay: 0.1s
      - servo.write:
          level: 4%
number:
  - platform: template
    min_value: -100
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - servo.write:
            level: !lambda 'return x / 100.0;'
servo:
  - id: my_servo1
    output: ledc_output1
output:
  - platform: ledc
    pin: GPIO27
    frequency: 50 Hz
 楼主| 发表于 2023-1-23 02:23:21 | 显示全部楼层
日志也没有问题,舵机确定是好的:
 楼主| 发表于 2023-1-23 06:20:32 | 显示全部楼层
问题已解决: 主要原因gpio使用两次
代码如下:
switch:
    optimistic: true
    turn_on_action:
      - servo.write:
          level: -30%
      - delay: 0.1s
      - servo.write:
          level: -6%
    turn_off_action:
      - servo.write:
          level: +14%
      - delay: 0.1s
      - servo.write:
          level: -6%
servo:
  - id: my_servo1
output:
  - platform: ledc
    pin: GPIO14
    frequency: 50 Hz
发表于 2023-1-24 12:09:20 | 显示全部楼层
我有个ESP32-C3的模块,更新到最新版也不正常,真是奇怪!
GMT+8, 2025-12-17 09:11 , Processed in 0.647779 second(s), 10 queries , MemCached On.
