查看: 8710|回复: 10
[求助] 有梯子,安装卡在准备界面如何解决,有日志
发表于 2023-1-19 14:12:21 | 显示全部楼层 |阅读模式
[size=1.96em]Preparing Home Assistant
[04:21:26] INFO: Using udev information from host
[04:21:26] INFO: Starting local supervisor watchdog...
23-01-19 04:21:27 INFO (MainThread) [__main__] Initializing Supervisor setup
23-01-19 12:21:27 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-01-19 12:21:27 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2022.12.1
23-01-19 12:21:27 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-01-19 12:21:27 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2022.11.2']
23-01-19 12:21:27 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-01-19 12:21:27 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:21:27 INFO (MainThread) [__main__] Setting up Supervisor
23-01-19 12:21:28 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-01-19 12:21:28 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-01-19 12:21:28 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-01-19 12:21:28 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 12:21:28 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-19 12:21:28 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 12:21:28 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-01-19 12:21:29 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-01-19 12:21:29 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0
23-01-19 12:21:29 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
23-01-19 12:21:29 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-01-19 12:21:29 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
23-01-19 12:21:29 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
23-01-19 12:21:29 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
23-01-19 12:21:29 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-19 12:21:31 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-01-19 12:21:31 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 12:21:31 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-01-19 12:21:31 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.4 / BootSlot A
23-01-19 12:21:31 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-01-19 12:21:31 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-01-19 12:21:31 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-01-19 12:23:31 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': HTTP/2 stream 1 was not closed cleanly before end of the underlying stream
23-01-19 12:23:31 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-01-19 12:23:31 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 5c53de3b
23-01-19 12:23:31 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
23-01-19 12:23:32 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
POST git-upload-pack (175 bytes)
error: RPC failed; curl 16 Error in the HTTP2 framing layer
fatal: expected flush after ref listing
23-01-19 12:23:32 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
23-01-19 12:23:32 INFO (MainThread) [supervisor.store] Loading add-ons from store: 41 all - 41 new - 0 remove
23-01-19 12:23:32 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-01-19 12:23:32 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-01-19 12:23:32 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-01-19 12:23:32 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:23:32 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-01-19 12:23:32 INFO (MainThread) [__main__] Running Supervisor
23-01-19 12:23:32 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-01-19 12:23:32 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-01-19 12:23:32 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-01-19 12:23:32 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-01-19 12:23:32 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-01-19 12:23:32 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-01-19 12:23:32 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-01-19 12:23:32 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-01-19 12:23:32 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-01-19 12:23:32 INFO (MainThread) [supervisor.host.info] Updating local host information
23-01-19 12:23:32 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.1.5
23-01-19 12:23:32 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.1.5.
23-01-19 12:23:32 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-01-19 12:23:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-01-19 12:23:32 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 12:23:32 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 12:23:32 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-19 12:23:32 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-01-19 12:23:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-01-19 12:23:34 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 12:23:34 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-01-19 12:23:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:23:36 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-01-19 12:23:36 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
s6-rc: info: service legacy-services: stopping
23-01-19 12:31:49 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
23-01-19 12:31:49 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
23-01-19 12:31:49 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
23-01-19 12:31:49 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
23-01-19 12:31:49 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
23-01-19 12:31:49 INFO (MainThread) [supervisor.core] Supervisor is down - 0
23-01-19 12:31:49 INFO (MainThread) [__main__] Closing Supervisor
[04:31:49] INFO: Watchdog restart after closing
s6-svwait: fatal: supervisor died
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[04:31:49] INFO: Supervisor restart after closing
[04:32:16] INFO: Using udev information from host
[04:32:16] INFO: Starting local supervisor watchdog...
23-01-19 04:32:18 INFO (MainThread) [__main__] Initializing Supervisor setup
23-01-19 12:32:18 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-01-19 12:32:18 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2022.12.1
23-01-19 12:32:18 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-01-19 12:32:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:32:18 INFO (MainThread) [__main__] Setting up Supervisor
23-01-19 12:32:19 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-01-19 12:32:19 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-01-19 12:32:19 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-01-19 12:32:19 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 12:32:19 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-19 12:32:19 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-30' coro=<DBus.sync_property_changes.<locals>.sync_property_change() done, defined at /usr/src/supervisor/supervisor/utils/dbus.py:180> exception=DBusFatalError('No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/IP4Config/3')>
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 101, in call_dbus
return await getattr(proxy_interface, method)(
File "/usr/local/lib/python3.10/site-packages/dbus_fast/aio/proxy_object.py", line 106, in method_fn
BaseProxyInterface._check_method_return(msg, intr_method.out_signature)
File "/usr/local/lib/python3.10/site-packages/dbus_fast/proxy_object.py", line 81, in _check_method_return
raise DBusError._from_message(msg)
dbus_fast.errors.DBusError: No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/IP4Config/3
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 198, in sync_property_change
await update(changed)
File "/usr/src/supervisor/supervisor/dbus/network/connection.py", line 133, in update
await self.ipv4.update()
File "/usr/src/supervisor/supervisor/dbus/interface.py", line 92, in update
self.properties = await self.dbus.get_properties(self.properties_interface)
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 168, in get_properties
return await self.properties.call_get_all(interface)
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 106, in call_dbus
raise DBus.from_dbus_error(err)
supervisor.exceptions.DBusFatalError: No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/IP4Config/3
future: <Task finished name='Task-32' coro=<DBus.sync_property_changes.<locals>.sync_property_change() done, defined at /usr/src/supervisor/supervisor/utils/dbus.py:180> exception=DBusFatalError('No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/IP6Config/3')>
dbus_fast.errors.DBusError: No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/IP6Config/3
File "/usr/src/supervisor/supervisor/dbus/network/connection.py", line 147, in update
await self.ipv6.update()
supervisor.exceptions.DBusFatalError: No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/IP6Config/3
23-01-19 12:32:19 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 12:32:19 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-01-19 12:32:19 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-01-19 12:32:19 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0
23-01-19 12:32:19 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-01-19 12:32:19 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
23-01-19 12:32:20 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0 - 172.30.32.5
23-01-19 12:32:20 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
23-01-19 12:32:20 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-01-19 12:32:20 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
23-01-19 12:32:21 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1 - 172.30.32.3
23-01-19 12:32:21 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-01-19 12:32:21 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
23-01-19 12:32:21 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-01-19 12:32:21 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
23-01-19 12:32:22 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0 - 172.30.32.4
23-01-19 12:32:22 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
23-01-19 12:32:22 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
23-01-19 12:32:22 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-01-19 12:32:22 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_multicast application
23-01-19 12:32:23 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0 - Host
23-01-19 12:32:23 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-19 12:32:27 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-01-19 12:32:27 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 12:32:27 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-01-19 12:32:27 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-01-19 12:32:27 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-01-19 12:32:27 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning homeassistant application
23-01-19 12:32:27 ERROR (MainThread) [supervisor.utils] Can't execute start while a task is in progress
23-01-19 12:32:28 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 12:32:28 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.4 / BootSlot A
23-01-19 12:32:28 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-01-19 12:32:28 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-01-19 12:32:28 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
23-01-19 12:34:28 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
23-01-19 12:34:28 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-01-19 12:34:28 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
23-01-19 12:34:28 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
23-01-19 12:34:29 INFO (MainThread) [supervisor.store] Loading add-ons from store: 44 all - 44 new - 0 remove
23-01-19 12:34:29 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-01-19 12:34:29 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-01-19 12:34:29 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-01-19 12:34:29 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:34:29 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-01-19 12:34:29 INFO (MainThread) [__main__] Running Supervisor
23-01-19 12:34:29 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-01-19 12:34:29 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-01-19 12:34:29 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-01-19 12:34:29 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-01-19 12:34:29 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-01-19 12:34:29 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-01-19 12:34:29 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-01-19 12:34:29 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-01-19 12:34:29 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-01-19 12:34:29 INFO (MainThread) [supervisor.host.info] Updating local host information
23-01-19 12:34:29 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-01-19 12:34:29 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.1.5
23-01-19 12:34:29 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.1.5.
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-01-19 12:34:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-01-19 12:34:29 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 12:34:29 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 12:34:29 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-19 12:34:29 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-01-19 12:34:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-01-19 12:34:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 12:34:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-01-19 12:34:32 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:34:32 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-01-19 12:34:32 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-01-19 12:38:35 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
23-01-19 12:38:35 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
23-01-19 12:38:35 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
23-01-19 12:38:35 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
23-01-19 12:38:35 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
23-01-19 12:38:35 INFO (MainThread) [supervisor.core] Supervisor is down - 0
23-01-19 12:38:35 INFO (MainThread) [__main__] Closing Supervisor
[04:38:35] INFO: Watchdog restart after closing
[04:38:35] INFO: Supervisor restart after closing
[04:39:48] INFO: Using udev information from host
[04:39:48] INFO: Starting local supervisor watchdog...
23-01-19 04:39:51 INFO (MainThread) [__main__] Initializing Supervisor setup
23-01-19 12:39:51 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-01-19 12:39:51 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2022.12.1
23-01-19 12:39:51 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-01-19 12:39:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:39:51 INFO (MainThread) [__main__] Setting up Supervisor
23-01-19 12:39:52 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-01-19 12:39:52 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-01-19 12:39:52 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-01-19 12:39:52 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 12:39:52 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-19 12:39:52 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 12:39:52 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-01-19 12:39:52 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-01-19 12:39:52 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0
23-01-19 12:39:52 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-01-19 12:39:52 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_cli application
23-01-19 12:39:54 INFO (SyncWorker_1) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0 - 172.30.32.5
23-01-19 12:39:54 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
23-01-19 12:39:54 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-01-19 12:39:54 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
23-01-19 12:39:55 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1 - 172.30.32.3
23-01-19 12:39:55 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-01-19 12:39:55 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
23-01-19 12:39:55 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-01-19 12:39:55 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_audio application
23-01-19 12:39:56 INFO (SyncWorker_1) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0 - 172.30.32.4
23-01-19 12:39:56 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
23-01-19 12:39:56 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
23-01-19 12:39:56 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-01-19 12:39:56 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_multicast application
23-01-19 12:39:57 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0 - Host
23-01-19 12:39:57 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-19 12:39:59 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-01-19 12:39:59 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 12:39:59 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-01-19 12:39:59 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-01-19 12:39:59 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-01-19 12:40:00 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning homeassistant application
23-01-19 12:40:00 ERROR (MainThread) [supervisor.utils] Can't execute start while a task is in progress
23-01-19 12:40:00 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 12:40:00 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.4 / BootSlot A
23-01-19 12:40:00 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
23-01-19 12:40:00 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-01-19 12:40:00 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
23-01-19 12:40:03 INFO (MainThread) [supervisor.store] Loading add-ons from store: 68 all - 68 new - 0 remove
23-01-19 12:40:03 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-01-19 12:40:03 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-01-19 12:40:03 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-01-19 12:40:03 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:40:03 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-01-19 12:40:03 INFO (MainThread) [__main__] Running Supervisor
23-01-19 12:40:03 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-01-19 12:40:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-01-19 12:40:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-01-19 12:40:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-01-19 12:40:03 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-01-19 12:40:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-01-19 12:40:03 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-01-19 12:40:03 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-01-19 12:40:03 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-01-19 12:40:03 INFO (MainThread) [supervisor.host.info] Updating local host information
23-01-19 12:40:03 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.1.5
23-01-19 12:40:03 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.1.5.
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-01-19 12:40:03 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 12:40:03 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-01-19 12:40:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-01-19 12:40:03 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-19 12:40:03 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-01-19 12:40:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-01-19 12:40:05 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 12:40:05 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-01-19 12:40:06 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:40:06 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-01-19 12:40:06 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-01-19 12:52:49 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
23-01-19 12:52:49 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
23-01-19 12:52:49 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
23-01-19 12:52:49 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
23-01-19 12:52:49 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
23-01-19 12:52:49 INFO (MainThread) [supervisor.core] Supervisor is down - 0
23-01-19 12:52:49 INFO (MainThread) [__main__] Closing Supervisor
[04:52:49] INFO: Watchdog restart after closing
[04:52:49] INFO: Supervisor restart after closing
[04:53:14] INFO: Using udev information from host
[04:53:14] INFO: Starting local supervisor watchdog...
23-01-19 04:53:16 INFO (MainThread) [__main__] Initializing Supervisor setup
23-01-19 12:53:16 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-01-19 12:53:16 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2022.12.1
23-01-19 12:53:16 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-01-19 12:53:16 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:53:16 INFO (MainThread) [__main__] Setting up Supervisor
23-01-19 12:53:17 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-01-19 12:53:17 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-01-19 12:53:17 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-01-19 12:53:17 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 12:53:17 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-19 12:53:17 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 12:53:17 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-01-19 12:53:17 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-01-19 12:53:17 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0
23-01-19 12:53:17 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-01-19 12:53:17 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
23-01-19 12:53:18 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0 - 172.30.32.5
23-01-19 12:53:18 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
23-01-19 12:53:18 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-01-19 12:53:18 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
23-01-19 12:53:18 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1 - 172.30.32.3
23-01-19 12:53:18 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-01-19 12:53:18 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
23-01-19 12:53:18 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-01-19 12:53:18 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
23-01-19 12:53:19 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0 - 172.30.32.4
23-01-19 12:53:19 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
23-01-19 12:53:19 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
23-01-19 12:53:19 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-01-19 12:53:19 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_multicast application
23-01-19 12:53:20 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0 - Host
23-01-19 12:53:20 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-19 12:53:22 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-01-19 12:53:22 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 12:53:22 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-01-19 12:53:22 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-01-19 12:53:22 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-01-19 12:53:22 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning homeassistant application
23-01-19 12:53:22 ERROR (MainThread) [supervisor.utils] Can't execute start while a task is in progress
23-01-19 12:53:22 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 12:53:22 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.4 / BootSlot A
23-01-19 12:53:23 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
23-01-19 12:53:23 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
23-01-19 12:53:23 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
23-01-19 12:53:23 INFO (MainThread) [supervisor.store] Loading add-ons from store: 68 all - 68 new - 0 remove
23-01-19 12:53:23 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-01-19 12:53:23 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-01-19 12:53:23 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-01-19 12:53:23 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:53:23 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-01-19 12:53:23 INFO (MainThread) [__main__] Running Supervisor
23-01-19 12:53:23 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-01-19 12:53:23 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-01-19 12:53:23 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-01-19 12:53:23 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-01-19 12:53:23 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-01-19 12:53:23 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-01-19 12:53:23 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-01-19 12:53:23 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-01-19 12:53:23 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-01-19 12:53:23 INFO (MainThread) [supervisor.host.info] Updating local host information
23-01-19 12:53:23 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.1.5
23-01-19 12:53:23 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.1.5.
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-01-19 12:53:23 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-01-19 12:53:23 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-01-19 12:53:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-01-19 12:53:23 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-01-19 12:53:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-01-19 12:53:25 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 12:53:25 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-01-19 12:53:27 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 12:53:27 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-01-19 12:53:27 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-01-19 13:36:02 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
23-01-19 13:36:02 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
23-01-19 13:36:02 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
23-01-19 13:36:02 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
23-01-19 13:36:02 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
23-01-19 13:36:02 INFO (MainThread) [supervisor.core] Supervisor is down - 0
23-01-19 13:36:02 INFO (MainThread) [__main__] Closing Supervisor
[05:36:02] INFO: Watchdog restart after closing
[05:36:02] INFO: Supervisor restart after closing
[05:36:29] INFO: Using udev information from host
[05:36:29] INFO: Starting local supervisor watchdog...
23-01-19 05:36:31 INFO (MainThread) [__main__] Initializing Supervisor setup
23-01-19 13:36:31 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-01-19 13:36:31 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2022.12.1
23-01-19 13:36:31 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-01-19 13:36:31 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 13:36:31 INFO (MainThread) [__main__] Setting up Supervisor
23-01-19 13:36:32 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-01-19 13:36:32 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-01-19 13:36:32 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-01-19 13:36:32 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 13:36:32 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-19 13:36:32 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 13:36:32 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-01-19 13:36:33 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-01-19 13:36:33 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0
23-01-19 13:36:33 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-01-19 13:36:33 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
23-01-19 13:36:33 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0 - 172.30.32.5
23-01-19 13:36:33 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
23-01-19 13:36:33 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-01-19 13:36:33 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
23-01-19 13:36:34 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1 - 172.30.32.3
23-01-19 13:36:34 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-01-19 13:36:34 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
23-01-19 13:36:34 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-01-19 13:36:34 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
23-01-19 13:36:35 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0 - 172.30.32.4
23-01-19 13:36:35 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
23-01-19 13:36:35 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
23-01-19 13:36:35 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-01-19 13:36:35 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_multicast application
23-01-19 13:36:36 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0 - Host
23-01-19 13:36:36 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-19 13:36:39 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-01-19 13:36:39 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 13:36:39 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-01-19 13:36:39 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-01-19 13:36:39 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-01-19 13:36:39 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning homeassistant application
23-01-19 13:36:39 ERROR (MainThread) [supervisor.utils] Can't execute start while a task is in progress
23-01-19 13:36:39 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-01-19 13:36:40 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.4 / BootSlot A
23-01-19 13:36:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
23-01-19 13:36:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
23-01-19 13:36:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
23-01-19 13:36:40 INFO (MainThread) [supervisor.store] Loading add-ons from store: 68 all - 68 new - 0 remove
23-01-19 13:36:40 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-01-19 13:36:40 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-01-19 13:36:40 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-01-19 13:36:40 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 13:36:40 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-01-19 13:36:40 INFO (MainThread) [__main__] Running Supervisor
23-01-19 13:36:40 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-01-19 13:36:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-01-19 13:36:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-01-19 13:36:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-01-19 13:36:40 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-01-19 13:36:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-01-19 13:36:40 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-01-19 13:36:40 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-01-19 13:36:40 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-01-19 13:36:40 INFO (MainThread) [supervisor.host.info] Updating local host information
23-01-19 13:36:40 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.1.5
23-01-19 13:36:40 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.1.5.
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-01-19 13:36:40 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-01-19 13:36:40 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-01-19 13:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-01-19 13:36:41 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-01-19 13:36:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-01-19 13:36:42 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-19 13:36:42 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-01-19 13:36:44 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-19 13:36:44 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-01-19 13:36:44 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
(this can take up to 20 minutes)
 楼主| 发表于 2023-1-19 14:13:44 | 显示全部楼层
目前是已经进入到这个8123界面,一直在等待,请问啥情况,登陆1~2小时了,有用蓝云
 楼主| 发表于 2023-1-19 14:14:47 | 显示全部楼层
是用的虚拟机安装,期间重启了几次
 楼主| 发表于 2023-1-19 14:22:07 | 显示全部楼层
所以是要一直等吗
 楼主| 发表于 2023-1-19 17:34:55 | 显示全部楼层
已经解决 等好了
jjcs 手机认证
发表于 2023-1-19 18:04:00 | 显示全部楼层
正常科学到位,几分钟就能安装超过,很明显代理方法有问题
发表于 2023-4-8 21:01:57 | 显示全部楼层
等了多久,我等了一下午了,一直这个界面
kkne
发表于 2023-6-25 22:06:49 | 显示全部楼层
我也一直在这个页面
发表于 2023-11-9 20:45:22 | 显示全部楼层
虚拟机怎么挂梯子呢
发表于 2023-11-9 22:46:43 | 显示全部楼层
见龙在田 发表于 2023-11-9 20:45
虚拟机怎么挂梯子呢
主路由有条件挂梯子的时候在主路由上挂着,主路由挂不了就再开一个Openwrt虚拟机,配置好后关主路由dhcp,让op接管dhcp。。。然后haos开机时自动获取op的网关。
GMT+8, 2025-12-17 07:28 , Processed in 0.764157 second(s), 12 queries , MemCached On.
