查看: 5595|回复: 13
[新手导航] cm311-1a能安装hassio吗
发表于 2023-1-17 13:10:46 | 显示全部楼层 |阅读模式
cm311-1a刷了最新的“[color=var(--color-accent-fg)]Armbian_23.02.0_amlogic_a311d_jammy_5.15.88_server_2023.01.16.img.gz”,安装各位大佬的教程,输入“sudo dpkg -i homeassistant-supervised.deb”后出错,根据提示Ubuntu 22.04.1 LTS is not supported!,是这系统不能刷hassio吗?
oot@armbian:~# sudo dpkg -i homeassistant-supervised.deb
(Reading database ... 37994 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[error] Ubuntu 22.04.1 LTS is not supported!
dpkg: error processing archive homeassistant-supervised.deb (--install):
 new homeassistant-supervised package pre-installation script subprocess returned error exit status 1
[info] Undo divert on abort-install
No diversion 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised', none removed.
[info] Resetting debconf selections
[info] Removal complete, due to the complexity of this installation method,
[info] you will need to manually remove the containers created by the supervisor
Errors were encountered while processing:
发表于 2023-1-17 13:56:16 | 显示全部楼层
 楼主| 发表于 2023-1-17 14:06:43 | 显示全部楼层
谢谢,我试一试。
发表于 2023-1-17 22:02:35 来自手机 | 显示全部楼层
supervised只支持debian
 楼主| 发表于 2023-1-17 22:37:30 | 显示全部楼层
网上教程:
过一会儿会进入一个蓝屏让你选择系统架构,选择qemuarm-64
我的cm311-a竟然不出现蓝色界面,可以选择架构qemuarm-64,最后变成下图:
docker
docker
发表于 2023-1-18 07:42:20 | 显示全部楼层
官方安装步骤:
一、apt-get install \
apparmor \
jq \
wget \
curl \
udisks2 \
libglib2.0-bin \
network-manager \
dbus \
lsb-release \
systemd-journal-remote -y
二、 curl -fsSL get.docker.com | sh
三、wget https://github.com/home-assistan ... 1_linux_aarch64.deb
dpkg -i os-agent_1.4.1_linux_aarch64.deb
四、wget https://github.com/home-assistan ... tant-supervised.deb
 楼主| 发表于 2023-1-18 08:49:34 | 显示全部楼层
hassfan 发表于 2023-1-18 07:42
官方安装步骤:
一、apt-get install \
apparmor \
是的,按照上面的步骤。
可能是盒子没有连接显示器,我通过ssh远程连接安装的,没有弹出个蓝屏选择系统架构“qemuarm-64”,我试一试用键盘、显示器连接盒子,输入“dpkg -i homeassistant-supervised.deb”这个命令。
好多雷要排啊
发表于 2023-1-18 09:41:36 | 显示全部楼层
SSH连接也是有选择界面的
发表于 2023-1-18 14:24:09 | 显示全部楼层
envcom 发表于 2023-1-18 08:49
是的,按照上面的步骤。
可能是盒子没有连接显示器,我通过ssh远程连接安装的,没有弹出个蓝屏选择系统架 ...
SSH软件试试MobaXterm_Personal
 楼主| 发表于 2023-1-18 17:20:15 | 显示全部楼层
用的就是MobaXterm,我换成putty试试。
GMT+8, 2025-12-16 15:40 , Processed in 1.501682 second(s), 16 queries , MemCached On.
