查看: 2761|回复: 4
[求助] 二进制传感器的模块如何写? 事件如下
发表于 2023-1-17 12:03:55 | 显示全部楼层 |阅读模式
请教大家我想写一个二进制模板,就是当下面的绿米fp1传感器binary_sensor.fp1_new_presence的presence_event属性变为approach状态后,二进制模板里,定义新的二进制传感器属性为on.
这个如何写呀?
下面是侦测到的fp1传感器有人接近的事件
newspaper(108109588)  11:58:57
event_type: state_changed
data:
  entity_id: binary_sensor.fp1_new_presence
  old_state:
    state: "off"
    attributes:
      approach_distance: near
      device_temperature: 23
      linkquality: 211
      monitoring_mode: left_right
      motion_sensitivity: medium
      power_outage_count: 0
      presence: false
      presence_event: approach
因为利用fp1本身的二进制传感器侦测人存在时,太延迟了。所以想用这个办法。
 楼主| 发表于 2023-1-17 12:07:45 | 显示全部楼层
template:
- binary_sensor:
      - name: 移动感应fp1_new
        device_class: motion
        auto_off: 10
        state: "{{ is_device_attr('binary_sensor.fp1_new_presence', 'presence_event', 'approach') }} "
上面是我看了官网的介绍写的。但不成功。大家看看错在哪里?
 楼主| 发表于 2023-1-17 12:31:12 | 显示全部楼层
或者在z2m或zha里如何修改配置文件,就是绿米的fp1一但侦测到人,马上显示为在家。而不是等到三秒后。
3万
发表于 2023-1-17 14:31:12 | 显示全部楼层
newspaper 发表于 2023-1-17 12:07
template:
- binary_sensor:
      - name: 移动感应fp1_new
auto_off time (optional)
Requires a trigger. After how much time the entity should turn off after it rendered ‘on’.
看文档说需要增加一项触发条件。
template:
  - trigger:
      - platform: state
        attribute: presence_event
    binary_sensor:
      - name: 移动感应fp1_new
            auto_off: 10
不知道这个 presence_event 状态变化来触发行不行
 楼主| 发表于 2023-1-17 15:43:58 | 显示全部楼层
Requires a trigger. After how much time the entity should turn off after  ...
非常感谢! 可以了!
GMT+8, 2025-12-17 06:41 , Processed in 0.709166 second(s), 6 queries , MemCached On.
