查看: 8845|回复: 3
[已解决] 求虚拟开关
发表于 2017-12-1 23:22:36 | 显示全部楼层 |阅读模式
求助大神下面这2个script怎么整成一个开关?谢谢啦
script:
tv_power_off:
  sequence:
    - service: broadlink.send_packet_172_16_1_59
      data:
        packet:
          - "AAAAAAAAAA"
    - delay:
        seconds: 0.5
      data:
        packet:
          - "AAAAAAAAAA"
tv_power_on:
  sequence:
      data:
        packet:
          - "AAAAAAAAAA"
wqqs 手机认证
活跃会员
发表于 2017-12-2 22:39:06 | 显示全部楼层
可以参考这个https://home-assistant.io/components/switch.template/
switch:
  - platform: template
    switches:
      skylight:
        value_template: "{{ is_state('sensor.skylight', 'on') }}"
        turn_on:
          service: switch.turn_on
          data:
            entity_id: switch.skylight_open
        turn_off:
          data:
            entity_id: switch.skylight_close
 楼主| 发表于 2017-12-3 08:03:13 | 显示全部楼层
switch:
感谢,已经做了触发自动化搞定了。。。
发表于 2018-5-6 18:45:23 | 显示全部楼层
ruianyu 发表于 2017-12-3 08:03
感谢,已经做了触发自动化搞定了。。。
能分享一下怎么实现吗?我想实现一个批量遥控操作,就是小米万能遥控:
1、打开蓝光机;
2、间隔2秒;
3、打开功放;
4、间隔3秒;
5、切换功放输入;
这样的批量遥控处理。谢谢!
GMT+8, 2025-11-6 19:24 , Processed in 1.022926 second(s), 6 queries , MemCached On.
