查看: 3056|回复: 1
[求助] 关于ESPhome通过水墨屏做数据看板的一些疑问。
发表于 2023-1-7 18:05:34 | 显示全部楼层 |阅读模式
发表于 2023-1-9 00:04:49 | 显示全部楼层
1.54in
1.54inv2
2.13in - not tested
2.13in-ttgo - T5_V2.3 tested. Also works for Wemos D1 Mini ePaper Shield 2.13 1.0.0 “LOLIN”
2.13in-ttgo-b73 - T5_V2.3 with B73 display tested
2.13in-ttgo-b74 - T5_V2.3.1 with B74 display tested
2.13in-ttgo-b1 - T5_V2.3 with B1 display tested
2.13in-ttgo-dke - T5_V2.3 with DKE group display (DEPG0213BN) tested
2.70in - currently not working with the HAT Rev 2.1 version
2.90in
2.90inv2
2.90in-b - B/W rendering only
4.20in
4.20in-bV2 - B/W rendering only
5.83in
7.50in
7.50in-bV2 - also supports v3, B/W rendering only
7.50in-bc - display with version sticker ‘(C)’ on the back, B/W rendering only
7.50inV2 - Can’t use with an ESP8266 as it runs out of RAM
7.50inV2alt (alternative version to the above 7.50inV2)
7.50in-hd-b - Can’t use with an ESP8266 as it runs out of RAM
以上是esphome的文档写的支持的型号。实际上有一些佳显的也能用微雪驱动,我知道的有2.9寸和4.2寸佳显都能用微雪驱动,其他我没有试过了附地址: https://esphome.io/components/di ... iguration-variables
GMT+8, 2025-12-18 15:08 , Processed in 1.041349 second(s), 10 queries , MemCached On.
