查看: 1839|回复: 0
[求助] Supervisor无法更新怎么办?
发表于 2022-12-18 12:40:28 | 显示全部楼层 |阅读模式
日志如下:Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:260
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 2022年12月17日 11:22:29 (1 occurrences)
Last logged: 2022年12月17日 11:22:29
[281473552677712] Error updating Home Assistant Supervisor: Abort update because of an issue with AppArmor: Can't fetch AppArmor profile https://version.home-assistant.io/apparmor.txt: Cannot connect to host version.home-assistant.io:443 ssl:default [Try again]
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 258, in async_install
    await async_update_supervisor(self.hass)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 45, in _wrapper
    raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Abort update because of an issue with AppArmor: Can't fetch AppArmor profile https://version.home-assistant.io/apparmor.txt: Cannot connect to host version.home-assistant.io:443 ssl:default [Try again]
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 202, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1738, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 207, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 931, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 413, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 260, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Abort update because of an issue with AppArmor: Can't fetch AppArmor profile https://version.home-assistant.io/apparmor.txt: Cannot connect to host version.home-assistant.io:443 ssl:default [Try again]
GMT+8, 2025-12-18 19:05 , Processed in 0.061507 second(s), 6 queries , MemCached On.
