查看: 2190|回复: 2
[求助] 【请版主删帖,莫名其妙又好用了】更新最新版2022.12.3后SM...
发表于 2022-12-13 09:54:05 | 显示全部楼层 |阅读模式
昨天晚上更新了最新的系统以后就收不到通知邮件了,到开发者工具里的服务里也没有邮件通知的这个服务项了,日志里错误代码是这样的,我看不懂,不知道是哪里出了问题。
Logger: homeassistant.components.notify
Source: components/smtp/notify.py:140
Integration: 通知 (documentation, issues)
First occurred: 00:45:21 (3 occurrences)
Last logged: 00:45:21
Error setting up platform smtp
  File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 92, in async_setup_platform
    notify_service = await hass.async_add_executor_job(
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 92, in get_service
    if mail_service.connection_is_valid():
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 154, in connection_is_valid
    server = self.connect()
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 140, in connect
    mail = smtplib.SMTP(self._server, self._port, timeout=self._timeout)
  File "/usr/local/lib/python3.10/smtplib.py", line 255, in __init__
    (code, msg) = self.connect(host, port)
  File "/usr/local/lib/python3.10/smtplib.py", line 343, in connect
    (code, msg) = self.getreply()
  File "/usr/local/lib/python3.10/smtplib.py", line 405, in getreply
    raise SMTPServerDisconnected("Connection unexpectedly closed")
smtplib.SMTPServerDisconnected: Connection unexpectedly closed
ztrx 手机认证
发表于 2022-12-13 15:00:09 | 显示全部楼层
2022.12.4了
 楼主| 发表于 2022-12-13 21:57:36 | 显示全部楼层
马上去更新了下,发现还是没用,哎,不会就这样废了吧,自从微信企业不能用了以后就很烦恼了
GMT+8, 2025-12-16 14:19 , Processed in 0.484770 second(s), 7 queries , MemCached On.
