查看: 3186|回复: 4
[技术探讨] HomeAssistant的ios APP没法连接
发表于 2022-12-9 20:51:04 | 显示全部楼层 |阅读模式
我用的是群晖docker里安装了HomeAssistant
配置好下载了appstore里面的HomeAssistant的APP
但是在局域网内都无法连接
是哪里要配置吗
比如我是这样的http://192.168.X.X:8123
的地址,提示我连接被拒绝了
但是电脑能访问啊
是我哪里没有配置吗
我看配置里面的外部网络访问写了禁止
但是点进去又是空白的,没有可以配置的地方
 楼主| 发表于 2022-12-9 22:13:58 | 显示全部楼层
晕死,下了一个安卓的客户端就是可以连的,为啥啊
发表于 2022-12-10 01:20:29 | 显示全部楼层
我也是  ios客户端   错误代码是webhook...error3   然而safari打开网页版可以
发表于 2022-12-10 01:23:17 | 显示全部楼层
这个是我的错误日志
Logger: homeassistant.components.webhook
Source: components/mobile_app/helpers.py:45
Integration: Webhook (documentation, issues)
First occurred: 2022年12月9日 22:41:37 (11 occurrences)
Last logged: 2022年12月9日 22:41:38
Error processing webhook 84974fe67d6dd8b2098608307fe98815f52ae4073a16061c18a8f22485caa64e
  File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 104, in async_handle_webhook
    response = await webhook["handler"](hass, webhook_id, request)
  File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 193, in handle_webhook
    webhook_payload = _decrypt_payload(config_entry.data[CONF_SECRET], enc_data)
  File "/usr/src/homeassistant/homeassistant/components/mobile_app/helpers.py", line 80, in _decrypt_payload
    message = decrypt(ciphertext, key)
  File "/usr/src/homeassistant/homeassistant/components/mobile_app/helpers.py", line 45, in decrypt
    return SecretBox(key).decrypt(ciphertext, encoder=Base64Encoder)
  File "/usr/local/lib/python3.9/site-packages/nacl/secret.py", line 130, in decrypt
    plaintext = nacl.bindings.crypto_secretbox_open(ciphertext,
  File "/usr/local/lib/python3.9/site-packages/nacl/bindings/crypto_secretbox.py", line 77, in crypto_secretbox_open
    ensure(res == 0, "Decryption failed. Ciphertext failed verification",
  File "/usr/local/lib/python3.9/site-packages/nacl/exceptions.py", line 81, in ensure
    raise raising(*args)
nacl.exceptions.CryptoError: Decryption failed. Ciphertext failed verification
发表于 2022-12-12 12:13:04 | 显示全部楼层
我也是这个情况,很奇怪,安卓版可以
GMT+8, 2026-1-18 06:35 , Processed in 0.585461 second(s), 6 queries , MemCached On.
