查看: 2017|回复: 0
[求助] ha报错 Command failed
发表于 2022-12-8 20:43:44 | 显示全部楼层 |阅读模式
最近ha连续报错
Logger: homeassistant.components.command_line
Source: components/command_line/__init__.py:48
Integration: command_line (documentation, issues)
First occurred: 19:02:49 (97 occurrences)
Last logged: 20:38:50
Command failed (with return code 1): cat /sys/class/thermal/thermal_zone0/temp
不太懂啥意思,通过英文翻译,可能是命令行错误,但不知道怎么进一步查找问题,麻烦坛子大佬指明解决方案
下面是yaml文件中的代码
# CPU 温度
- platform: command_line
  name: CPU Temperature
  command: "cat /sys/class/thermal/thermal_zone0/temp"
  unit_of_measurement: "°C"
  value_template: '{{ value | multiply(0.001) | round(1) }}'
代码是抄作业抄的,是不是代码有问题?
GMT+8, 2025-11-2 16:57 , Processed in 0.217223 second(s), 6 queries , MemCached On.
