楼主: wang200624002
[求助] 已安装好系统,接入小米网关失败,已尝试刷不同系统
发表于 2017-12-2 20:23:16 | 显示全部楼层
新手安装hassio多方便啊。
发表于 2017-12-6 09:49:18 | 显示全部楼层
我换了个路由器就好了,应该和路由设置有关系吧
教程狂人论坛风云人物突出贡献
发表于 2017-12-6 10:42:59 来自手机 | 显示全部楼层
明显是依赖的python模块没装好
发表于 2017-12-21 14:08:15 | 显示全部楼层
wang200624002 发表于 2017-12-1 22:59
没有,试了退一格也不行
我换了路由器解决了,配置格式没改就好了,应该是网络的事吧。
发表于 2017-12-31 16:05:35 | 显示全部楼层
homeassistant@raspberrypi:/home/pi $ source /srv/homeassistant/homeassistant_venv/bin/activate
(homeassistant_venv) homeassistant@raspberrypi:/home/pi $ pip3 install pyxiaomigateway==0.6.0
Downloading/unpacking pyxiaomigateway==0.6.0
  Downloading PyXiaomiGateway-0.6.0.tar.gz
  Running setup.py (path:/tmp/pip-build-babkkcni/pyxiaomigateway/setup.py) egg_info for package pyxiaomigateway
Downloading/unpacking cryptography==2.1.1 (from pyxiaomigateway==0.6.0)
  Downloading cryptography-2.1.1.tar.gz (441kB): 441kB downloaded
  Running setup.py (path:/tmp/pip-build-babkkcni/cryptography/setup.py) egg_info for package cryptography
    error in cryptography setup command: Invalid environment marker: platform_python_implementation != 'PyPy'
    Complete output from command python setup.py egg_info:
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-babkkcni/cryptography
Storing debug log for failure in /home/homeassistant/.pip/pip.log
小米网关连不上,提示以上错误,怎么解决?
 楼主| 发表于 2018-1-7 17:33:47 | 显示全部楼层
把网关、路由器、树莓派全部断电,重新通电启动,竟然可以了
GMT+8, 2025-12-25 11:55 , Processed in 0.937361 second(s), 13 queries , MemCached On.
