查看: 2903|回复: 2
[插件集成] SONOFF插件第二天必定失效报错
发表于 2022-12-5 17:44:57 | 显示全部楼层 |阅读模式
一直用支持易维联的SONOFF插件,插件地址https://github.com/AlexxIT/SonoffLAN,稳定可靠,比易维联官方反应都还快,最近HA升级后发现基本每天都要失去反应,系统日志也报错:
ARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
说未经过测试?这么好的插件,HA竟然要不支持!!!
发表于 2022-12-5 19:32:10 | 显示全部楼层
这相当于只是一个队第三方插件的免责声明,和你的问题没啥关系啊
发表于 2022-12-5 20:42:59 | 显示全部楼层
哈哈~~!!SONOFF的东西想用的爽还是得刷ESPhome
GMT+8, 2026-1-17 23:55 , Processed in 0.047245 second(s), 7 queries , MemCached On.
