查看: 2580|回复: 5
[求助] 群辉下安装的nodered安装了一些流程后无限重启,求解决
发表于 2022-11-29 19:33:19 | 显示全部楼层 |阅读模式
群辉下安装的nodered安装了一些流程后无限重启    下面是日志,求大神帮我看下哪里出错了,应该怎么解决?
nodered-node-red1
date        stream        content
2022-11-29 11:05:54        stdout            at async Websocket.connect (/data/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:82:23)
2022-11-29 11:05:54        stdout            at processTicksAndRejections (node:internal/process/task_queues:96:5)
2022-11-29 11:05:54        stdout            at /data/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:112:29
2022-11-29 11:05:54        stdout        29 Nov 19:05:52 - [error] Error: Invalid access token for websocket
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [red] Uncaught Exception:
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] [mqtt-broker:123] Connected to broker: mqtt://192.168.31.253:1883
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] [mqtt-broker:MQTT-NAS] Connected to broker: mqtt://192.168.31.253:1883
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [api-current-state:获取设备gps信息] InputError:  device_tracker.car
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] [server:Home Assistant1] Connecting to http://xia***hui.cn:8123
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] [server:Home Assistant] Connecting to http://xia***hui.cn:8123
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] [bizwechat-input:微信] listening on port 3001
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] Started flows
2022-11-29 11:05:52        stdout        }
2022-11-29 11:05:52        stdout          username: '35***08'
2022-11-29 11:05:52        stdout          ],
2022-11-29 11:05:52        stdout            'a2697adbb4953f4f'
2022-11-29 11:05:52        stdout            'efb55eb5d2fd6615',
2022-11-29 11:05:52        stdout            '0a061e74ad578b34',
2022-11-29 11:05:52        stdout            '454adb3a01cb8a5b',
2022-11-29 11:05:52        stdout            'f2558d80e7939244',
2022-11-29 11:05:52        stdout            '51d1a419.9011ac',
2022-11-29 11:05:52        stdout            'eb68dd51.42101',
2022-11-29 11:05:52        stdout            '6934e7e6ed0d60ef',
2022-11-29 11:05:52        stdout          _users: [
2022-11-29 11:05:52        stdout          name: '',
2022-11-29 11:05:52        stdout          credentials: { username: '35***08', password: '91***kh' },
2022-11-29 11:05:52        stdout          send: [Function: NOOP_SEND],
2022-11-29 11:05:52        stdout          _wireCount: 0,
2022-11-29 11:05:52        stdout          wires: [],
2022-11-29 11:05:52        stdout          _inputCallbacks: null,
2022-11-29 11:05:52        stdout          _inputCallback: null,
2022-11-29 11:05:52        stdout          _closeCallbacks: [],
2022-11-29 11:05:52        stdout          g: undefined,
2022-11-29 11:05:52        stdout          z: undefined,
2022-11-29 11:05:52        stdout          type: 'xiaoai-tts-configurator',
2022-11-29 11:05:52        stdout          id: '3996f445dd39a84b',
2022-11-29 11:05:52        stdout        Node {
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [mqtt in:97f7d6632aed37bf] missing broker configuration
2022-11-29 11:05:52        stdout        key: 7265b54de3a41a5554280169ead329eb
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:f630d5e3bc7c9376] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:92255df0762477fb] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:70fa8d114ef045b3] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:d44043343a455d4a] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:8b670fac79b6b0dc] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:485f07ce3199bb83] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:437aa8323a0e86ef] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:07c1d27f0e881e6e] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:b6f0b6bfef5e882c] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:89baf0e4aa23bcc9] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:629369baf3067e34] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:23996c57fe9f99a5] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:6505d98d229d41b5] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [error] [ha-entity-config:018e513df4dfd26b] Error: Invalid server config
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] Starting flows
2022-11-29 11:05:52        stdout        ---------------------------------------------------------------------
2022-11-29 11:05:52        stdout        file using your chosen key the next time you deploy a change.
2022-11-29 11:05:52        stdout        your settings file. Node-RED will then re-encrypt your credentials
2022-11-29 11:05:52        stdout        You should set your own key using the 'credentialSecret' option in
2022-11-29 11:05:52        stdout        your credentials.
2022-11-29 11:05:52        stdout        file will not be recoverable, you will have to delete it and re-enter
2022-11-29 11:05:52        stdout        If the system-generated key is lost for any reason, your credentials
2022-11-29 11:05:52        stdout        Your flow credentials file is encrypted using a system-generated key.
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [warn]
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] Server now running at http://127.0.0.1:1880/
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] Flows file     : /data/flows.json
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [warn] Projects disabled : editorTheme.projects.enabled=false
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] User directory : /data
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] Context store  : 'default' [module=memory]
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [info] Settings file  : /data/settings.js
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [warn] ------------------------------------------------------
2022-11-29 11:05:52        stdout        29 Nov 19:05:52 - [warn] [node-red-qnap-blockly/blockly] 'Blockly' already registered by module node-red-contrib-blockly
2022-11-29 11:05:51        stdout        29 Nov 19:05:51 - [warn] [RequestValidator] Registered invalid property name 'sampleNodeColour'. Properties for this node must start with 'requestValidator'
2022-11-29 11:05:32        stdout        29 Nov 19:05:32 - [info] Loading palette nodes
2022-11-29 11:05:31        stdout        29 Nov 19:05:31 - [info] Linux 4.4.59+ x64 LE
2022-11-29 11:05:31        stdout        29 Nov 19:05:31 - [info] Node.js  version: v16.16.0
2022-11-29 11:05:31        stdout        29 Nov 19:05:31 - [info] Node-RED version: v3.0.2
2022-11-29 11:05:31        stdout        ===================
2022-11-29 11:05:31        stdout        Welcome to Node-RED
2022-11-29 11:05:27        stdout            at async Websocket.connect (/data/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:82:23)
2022-11-29 11:05:27        stdout            at processTicksAndRejections (node:internal/process/task_queues:96:5)
2022-11-29 11:05:27        stdout            at /data/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:112:29
2022-11-29 11:05:27        stdout        29 Nov 19:05:27 - [error] Error: Invalid access token for websocket
2022-11-29 11:05:27        stdout        29 Nov 19:05:27 - [red] Uncaught Exception:
2022-11-29 11:05:27        stdout        29 Nov 19:05:26 - [info] [mqtt-broker:123] Connected to broker: mqtt://192.168.31.253:1883
2022-11-29 11:05:27        stdout        29 Nov 19:05:26 - [info] [mqtt-broker:MQTT-NAS] Connected to broker: mqtt://192.168.31.253:1883
2022-11-29 11:05:27        stdout        29 Nov 19:05:26 - [error] [api-current-state:获取设备gps信息] InputError:  device_tracker.car
2022-11-29 11:05:27        stdout        29 Nov 19:05:26 - [info] [server:Home Assistant1] Connecting to http://xia***hui.cn:8123
2022-11-29 11:05:27        stdout        29 Nov 19:05:26 - [info] [server:Home Assistant] Connecting to http://xia***hui.cn:8123
2022-11-29 11:05:27        stdout        29 Nov 19:05:26 - [info] [bizwechat-input:微信] listening on port 3001
2022-11-29 11:05:27        stdout        29 Nov 19:05:26 - [info] Started flows
2022-11-29 11:05:27        stdout        }
2022-11-29 11:05:27        stdout          username: '35***08'
2022-11-29 11:05:27        stdout          ],
2022-11-29 11:05:27        stdout            'a2697adbb4953f4f'
发表于 2022-11-30 08:40:56 | 显示全部楼层
权限吧
 楼主| 发表于 2022-11-30 09:33:29 | 显示全部楼层
权限是给完了的
发表于 2022-11-30 11:28:24 | 显示全部楼层
想想最后安装了啥,然后删掉再进
 楼主| 发表于 2022-11-30 20:38:48 | 显示全部楼层
602293544 发表于 2022-11-30 11:28
想想最后安装了啥,然后删掉再进
在哪删?
发表于 2022-12-1 21:09:42 | 显示全部楼层
企业微信通知?看错误是accesstoken错误,可能是获取失败了,检查应用ID和secret是否配置正确。
GMT+8, 2025-12-16 00:04 , Processed in 1.415065 second(s), 15 queries , MemCached On.
